Ambitious and a great idea. Right up your street.
M3A1 BY ILOVE KITS IN 1/35 SCALE LEND LEASE DIORAMA
Wow John that's looking great!
If I may make a suggestion regarding the water? With that much tank in whatever water product you decide upon, it's all around the wheels and tracks where you are going to trap air bubbles. I would recommend pre painting the product all over those areas to build up a smooth blob around them, possibly in stages, and letting it set first. After that the bulk of the water should be relatively straightforward . I imagine you will need some kind of masking, possibly plasticine,to define the water level where it goes inside those nasty areas. It will be tricky but well worth it.Comment
Thank you, various body parts have be used, some I actually drilled out , wired and fixed. Now of course the cleaning up.
I've had notification that some black primer is arriving later today , some plenty to do .Such fun .:nerd:Comment
with regard to the use of Plastcine, I mean you will need to create a 3-dimensional mask in the space above the waterline on the tank (behind the wheels) so that it's vaguely consistent with the water level of the river. That said, I'm sure there would be actual bubbles and disturbance there because it's moving so maybe it's not quite so critical.
blimey, one eye AND left -handed- what a combo:thinking:! you clearly are a man of exceptional talents :tears-of-joy:Comment
Hi John,
Having searched the web I now have a much better idea of what to look for in resins. There are resins that produce low temperatures when curing, some produce very few bubbles. A multitude of do and don'ts. Makes like craft resins that are produced that can go to to depths of over 70mm in one pour instead of having layer. That alone increases the time as each layer has to cure fully. More research will follow.:nerd:Comment
Since last Fridays much has been happening here at the Towers.
The base has had yet another layer of Mod Podge applied, followed by some garden soil , and a layer spray of IPA to allow the glues to spread more easily .
Now dry after a night next to the heater , all glue marks have gone, so painting can start.
Painting has also started on the figures, very thin coats of uniform colour.
Building up the colour in light coats. Once that is done the rest of the kit can be tackled.
These have dried a lot darker, more true to uniform tankies.
Thanks for looking in, comments welcome.
JRComment
