As I said the Wibble above while sanding the Tamiya tape off I dropped the whole thing on the floor !!!!!!
Saw the the turret had broken in three, luckily I'd not gone mad with the glue when assembling.
For some unknown reason the Tamiya tape which in the past has peeled off with out any great difficulty decided to stick to the resin.
After sanding by hand and getting nowhere fast out came to Bosch orbital sander , this managed slightly better.
In the end I used my Bosch jigsaw to remove a complete edge, it cut through the resin well and no doubt because I've had years of use with power tools I managed it well .Not some thing for a beginner to attempt.
Following a sanding of the surface around the tank I made up a final batch of resin, just 30 ml resin and 10 ml hardener. Strange to watch a sanded surface turn into a clear shinny surface. I let the resin flow over the front edge and made sure the front surface of the resin was fully coated as well .Left on some paint drying supports, covered with the bucket and after an hr looked to check for bubbles. None , looked good .
Tomorrow the check !
