Loving this John, bring it on!
Valentine Mk 1 1/35 scale AFV CLUB AF 35178.
Well done buddy a little perseverance and a step back every now and then to give yourself a pat on the back helps keep the right mind set , now you've primed up you can see it was worth the hassle ,look at it as the driving force to reach the part of the project that you enjoy the most you've had the smoke now bring on your fire.
Thanks for all your help recently as they say its good to talk. DaveComment
Thanks Neil.
Many thanks Steve.Comment
Evening all.
Much progress made on the base.
First thought I should show the size
For those that work in good old imperial , sorry.
Before sticking with double sided tape a check is made,
Here the tape is on, never easy to remove the cover to expose this part. Time to take it slowly along with keeping the face clean.
This photo show the tape stuck on, just about to cut to length.
Edging tape done, rough at this stage as an allowance is left for the top layer of material, in my case just some dry sand and soil.
Having done the veneering a cover is applied with tape.
You can see the hight left for the top layer with the veneer showing well above the white base .
About to spray a very heavy coat of thinned PVA. Used that original bottle of glue up and since made up my own. Remove that spray top , and wash out well before putting the bottle cap back on.
Soil added, still very wet and left to dry over night. Resulting in.
Some white just showing through so more glue was added and soil.
Removing the edge.
This where I am now, a little more cleaning of the veneer to do .
Thanks for looking in. JOHN.Comment
That is looking pretty impressive already. I’d say barrel up looks more desperate and stranded than barrel down.Comment
Just a thought John without some sort of break on the traverse ring surly it would be looking down going by weight firstComment
