Already looking full of promise. I like the little island idea. Definitely heading for a Blue Peter badge.
"What goes up - Must come down!"........Mykolaiv, Ukraine.
Thanks for the positive posts chaps.....
Sides built up and yet to be 'finger nailed' to texture the rock surface.
I've added the underwater rubble. i put in some foam board to the underside to bulk the stuff out nearer the water surface.
...a bit too much I fear , so I might scrape some out later. I'll see better when I 'speriment with some 'Waater'.
Cheers.
Ron👍 3🥰 1Comment
Thanks boys.
Slowly, slowly, catchy monkey.....
Colours added to the river banks.
I've also started to sort out the water element.
I don't like resin water one bit. Too much prep. and general messing about with and then the stuff doesn't settle to my liking...
To each his own though, eh?
Loosely fitted for now, I'm using a plastic lid from a 'Ding Ding' food container.
Still loads to do below the surface, so it's early stages whilst I get the feeling for this phase.
Cheers.
RonLast edited by spanner570; 21 November 2024, 11:49.👍 5🥰 1Comment
Hi Dave, a most excellent suggestion, but once I get everything in place, and there will be loads of 'obstructions', I will use silicone to texture the otherwise smooth surface water into a veritable maelstrom of dashing, gurgling liquid.....
...but thanks for the input none the less. Well appreciated.
RonComment
Thanks Steven.
Using plastic food container lids is so much easier than resin and I can work the surface 'till the cows come home.....Unlike resin!
Thanks for the positive post.👍 1Comment
👍 5Comment
