afrika korps - 2nd diorama
  • saguy
    • Feb 2011
    • 570
    hello all ... am attempting my 2nd diorama .. over the past month or so i have been working on the 3ton half track ... bit of a hard slog to be honest ...lots and lost of very small pieces. i have weathered it heavily as in my imaginatiion it has been strolling around the desert for a good couple of years so is a little battle weary. other components will be a anti tank emplacement with gun crew and a few afrika korps troops. depending on the space available there may also be a badly beaten up kubelwagen ... the anti tank gun will be on a rocky outcrop, the kubelwagen and half track down at the bottom with a rock strewn gully leading up to the gun. also maybe an area where the ammo and stores r being kept under some camo netting .. troops than placed strategically around .. this is quite ambitious for me but i will give it a go and see where i end up ....tx for looking lindsey
    [ATTACH]50376.IPB[/ATTACH]
    [ATTACH]50377.IPB[/ATTACH]
    [ATTACH]50378.IPB[/ATTACH]
    [ATTACH]50379.IPB[/ATTACH]
    [ATTACH]50380.IPB[/ATTACH]
    [ATTACH]50381.IPB[/ATTACH]
    [ATTACH]50382.IPB[/ATTACH]
    [ATTACH]50383.IPB[/ATTACH]
    [ATTACH]50384.IPB[/ATTACH]
  • stona
    • Jul 2008
    • 9889
    That looks good.
    Might I make one suggestion? Very often desert vehicles had mud or some other substance applied to the windscreen leaving just enough clear glass to see through. This was to prevent the sun reflecting off the glass and giving away the vehicles position to any enemy aircraft within miles.
    Here is a typical example.
    • saguy
      • Feb 2011
      • 570
      tx steve ... wil give that go ...rgds
      lindsey
        Looking excellent so far, Lindsey. I really like the weathered halftrack!
        • spanner570
          • 15437
          Nice job so far Lindsey, keep it up.
          I use well diluted PVA to do the windscreens as Steve suggests....Just apply carefully where you want the dust, then get some dust from wherever. I use the sweepings from the concrete garage floor. Sprinkle this on the windscreen then tap the residue off....Job done!
          Good luck with the dio.
          Ron
          • flyjoe180
            • Jan 2012
            • 12433
            • Joe
            • Earth
            Looking great Lindsey, this will be a very interesting diorama. Steve, I thought desert vehicles were just naturally dirty and noone cleaned them, so that is interesting info about the windscreens.
            • saguy
              • Feb 2011
              • 570
              hi there ... have been working on my diorama ... completed the 35mm anti tank gun and it's crew and have started on the diorama base ... hoping to add the tiling cement onto the base sometime tomorrow. Still working on the dak troops, a tent with a radio man and possibly a kubelwagen .... bit slow going but quite pleased with the work to date ...also added a pic of the scene that i found that i will use as a guideline
              rgds lindsey
              [ATTACH]51618.IPB[/ATTACH]
              [ATTACH]51619.IPB[/ATTACH]
              [ATTACH]51620.IPB[/ATTACH]
              [ATTACH]51621.IPB[/ATTACH]
              [ATTACH]51622.IPB[/ATTACH]
              [ATTACH]51623.IPB[/ATTACH]
              [ATTACH]51624.IPB[/ATTACH]
              [ATTACH]51625.IPB[/ATTACH]
              • stona
                • Jul 2008
                • 9889
                I found myself flying home from Edinburgh last week and as we approached Birmingham we were met by clear blue skies. Peering out of the window I tried to see the reflections from cars below and guess what? Some were flashing like heliographs,visible from miles away.
                  Nice work, looking good so far!!
                  You have chooise a original guideline, but I'm sure you will finished it with best result!!
                  Cheers.
                    • 22771
                    Starting to come together now Lindsey looking good
                    • saguy
                      • Feb 2011
                      • 570
                      hey there .... a few more progress pics. tiling cement added onto the diorama, then a handy little helper painted it for me with some left over paint and then covered in little stones and some pool filter sand ...cheers lindsey ...(note .. also added mud to the windscreen of the half track as per Steve's advice ... worked out ok i think ....
                      [ATTACH]51947.IPB[/ATTACH]
                      [ATTACH]51948.IPB[/ATTACH]
                      [ATTACH]51949.IPB[/ATTACH]
                      [ATTACH]51950.IPB[/ATTACH]
                      [ATTACH]51951.IPB[/ATTACH]
                      [ATTACH]51952.IPB[/ATTACH]
                      [ATTACH]51953.IPB[/ATTACH]
                      • flyjoe180
                        • Jan 2012
                        • 12433
                        • Joe
                        • Earth
                        That looks really good so far Lindsey.
                          fantastic work yoyr boy is doing.when do you start your bit?lol
                          mobear
                          • saguy
                            • Feb 2011
                            • 570
                            some more progress pics ... have added 2 sandbag emplacements, a rickety fence, a radio man, some desert looking plants etc etc ... still some stuff to go but it is coming along quite nicely .... cheers ....lindsey
                            [ATTACH]51992.IPB[/ATTACH]
                            [ATTACH]51993.IPB[/ATTACH]
                            [ATTACH]51994.IPB[/ATTACH]
                            [ATTACH]51995.IPB[/ATTACH]
                            • mossiepilot
                              • Jul 2011
                              • 2272
                              Coming along really well Linsey, a cracking piece of dio building mate.
                              Tony.
