This is my first full on attempt at a diorama. I’ve had the idea of doing a street scene for quite a few years & scratch building as much as I can. I was in the shed scratching my head as I often do after forgetting what I had gone out there for, when I looked straight at my 3-foot bow fronted aquarium doing nothing & thought that would make a very nice display case for a Dio! The bow front giving me even more width to take advantage of. So it all went from there.
The houses are made from balsa sheet & the odd bit of card & ply.
The cobbles, bricks, tiles etc were made with air clay. Bricks were stamped out individually with a piece of brass tube hammered into the shape and size of a brick & the same was done with the cobbles.
The brickwork on the red brick house was air clay rolled out into a sheet then the same was done with the brick stamp & aloud to dry (use cling film between clay & board you roll out on. It will stick & you will spend another 1.5 hours punching in the brickwork again.) Trust me! I then stuck the brick sheet to the balsa with aliphatic & cut out the window and doors.
The roof tile stamp was made with a piece of plastic sheet & shaped into a rough tile shape then stuck to a piece of balsa.
The buildings stonework was made with balsa mould & air clay.
[ATTACH]50077.vB[/ATTACH] [ATTACH]50078.vB[/ATTACH]
Balsa moulds were made for dragon’s teeth. Then a mixture of silver sand & tetrion filler was poured in.
I’ve used about 3kg of air clay.
Paints used Humbrol enamels, Tamiya acrylics, Vellejo matt & gloss clear acrylics, Daler Rowney water colours, System 3 acrylics (for figures flesh tones over white primer) & Winsor Newton oils for washes
The figures, armour etc is Tamiya except the seated figure, which is by Stalingrad
The barbed wire is by Aber.
The aquarium is light with a 120-led white strip light through sanded Perspex with a sheet of tissue paper. Which defuses the light beautifully & gives a even light across the aquarium.
Sorry about the quality of some of the photos.
[ATTACH]50079.vB[/ATTACH][ATTACH]50080.vB[/ATTACH][ATTACH]50081.vB[/ATTACH][ATTACH]50082.vB[/ATTACH][ATTACH]50083.vB[/ATTACH][ATTACH]50084.vB[/ATTACH][ATTACH]50085.vB[/ATTACH][ATTACH]50086.vB[/ATTACH][ATTACH]50087.vB[/ATTACH][ATTACH]50088.vB[/ATTACH]
[ATTACH]50089.vB[/ATTACH][ATTACH]50090.vB[/ATTACH][ATTACH]50091.vB[/ATTACH][ATTACH]50092.vB[/ATTACH][ATTACH]50093.vB[/ATTACH][ATTACH]50094.vB[/ATTACH][ATTACH]50095.vB[/ATTACH][ATTACH]50096.vB[/ATTACH][ATTACH]50097.vB[/ATTACH][ATTACH]50098.vB[/ATTACH][ATTACH]50099.vB[/ATTACH][ATTACH]50100.vB[/ATTACH][ATTACH]50101.vB[/ATTACH][ATTACH]50102.vB[/ATTACH][ATTACH]50103.vB[/ATTACH]
[ATTACH]52799.IPB[/ATTACH]
[ATTACH]52800.IPB[/ATTACH]
[ATTACH]52801.IPB[/ATTACH]
[ATTACH]52802.IPB[/ATTACH]
[ATTACH]52803.IPB[/ATTACH]
[ATTACH]52804.IPB[/ATTACH]
[ATTACH]52805.IPB[/ATTACH]
[ATTACH]52806.IPB[/ATTACH]
[ATTACH]52807.IPB[/ATTACH]
[ATTACH]52808.IPB[/ATTACH]
[ATTACH]52809.IPB[/ATTACH]
[ATTACH]52810.IPB[/ATTACH]
[ATTACH]52811.IPB[/ATTACH]
[ATTACH]52812.IPB[/ATTACH]
[ATTACH]52813.IPB[/ATTACH]
[ATTACH]52814.IPB[/ATTACH]
[ATTACH]52815.IPB[/ATTACH]
[ATTACH]52816.IPB[/ATTACH]
[ATTACH]52817.IPB[/ATTACH]
[ATTACH]52818.IPB[/ATTACH]
[ATTACH]52819.IPB[/ATTACH]
[ATTACH]52820.IPB[/ATTACH]
[ATTACH]52821.IPB[/ATTACH]
[ATTACH]52822.IPB[/ATTACH]
[ATTACH]52823.IPB[/ATTACH]
[ATTACH]52824.IPB[/ATTACH]
[ATTACH]52825.IPB[/ATTACH]
