Casualty of war
    Casualty of war
    Some time ago i was asked to show how i alter my 1/16 figures, well i have put my other figure to one side while i try to work out how i am going to do the base.
    Well here gose. I will start with the head & work down.
    [ATTACH]25420.vB[/ATTACH] [ATTACH]25421.vB[/ATTACH][ATTACH]25422.vB[/ATTACH][ATTACH]25423.vB[/ATTACH]
    [ATTACH]25424.vB[/ATTACH][ATTACH]25425.vB[/ATTACH][ATTACH]25426.vB[/ATTACH][ATTACH]25427.vB[/ATTACH]
    The mouth was drilled out with a size 0,3.5 drill and then carved out with a pointed blade to get the right shape, the same with the left eye just a bit smaller, i managed to keep the top eyelid intacted for better affect if you look closely at the completed head you can just make out i have managed to put a tunge in his mouth.
    I still need to paint the chin strap & buckel and the face needs a little work but it gives you the idea.
    I will be working on the body in the next few days as im on 12 hour night shift, will take pic's as i go along.
    Hope you like.
    John.
    [ATTACH]31620.IPB[/ATTACH]
    [ATTACH]31621.IPB[/ATTACH]
    [ATTACH]31622.IPB[/ATTACH]
    [ATTACH]31623.IPB[/ATTACH]
    [ATTACH]31624.IPB[/ATTACH]
    [ATTACH]31625.IPB[/ATTACH]
    [ATTACH]31626.IPB[/ATTACH]
    [ATTACH]31627.IPB[/ATTACH]
    [ATTACH]25457.vB[/ATTACH][ATTACH]25458.vB[/ATTACH][ATTACH]25459.vB[/ATTACH][ATTACH]25460.vB[/ATTACH][ATTACH]25461.vB[/ATTACH]
    Wooden butt ?? all will be reviled in the end product.
    John.
    [ATTACH]31656.IPB[/ATTACH]
    [ATTACH]31657.IPB[/ATTACH]
    [ATTACH]31658.IPB[/ATTACH]
    [ATTACH]31659.IPB[/ATTACH]
    [ATTACH]31660.IPB[/ATTACH]
    • spanner570
      • 15385
      Nice work on the SG44, John.
      Ron
        lovely work there im impressed.
        scott
          Just started the base, used an old Bonsi tree that i kept for a rainy day.
          [ATTACH]25542.vB[/ATTACH] [ATTACH]25543.vB[/ATTACH][ATTACH]25544.vB[/ATTACH][ATTACH]25545.vB[/ATTACH][ATTACH]25546.vB[/ATTACH]
          Hope you like.
          [ATTACH]31739.IPB[/ATTACH]
          [ATTACH]31740.IPB[/ATTACH]
          [ATTACH]31741.IPB[/ATTACH]
          [ATTACH]31742.IPB[/ATTACH]
          [ATTACH]31743.IPB[/ATTACH]
            An absolutely unbeleivable level of detail. Putting a tongue in is the sort of thing that really sets models such as this apart from all the rest. Many thanks for sharing the build, this is really going to be interesting to watch it go together.
              Hi all, just finished of the wall & put a figure in to give some scale to it. The figure is not the one that will be in this dio.
              [ATTACH]25569.vB[/ATTACH] [ATTACH]25570.vB[/ATTACH]
              Hope u like.
              [ATTACH]25599.vB[/ATTACH][ATTACH]25600.vB[/ATTACH]
              A little more & still going.
              [ATTACH]31766.IPB[/ATTACH]
              [ATTACH]31767.IPB[/ATTACH]
              [ATTACH]31782.IPB[/ATTACH]
              [ATTACH]31783.IPB[/ATTACH]
                • 18266
                Nice base there John. Looks like you might of done a bit of dry stone walling in your life? Nice tree by the way. Have wondered about using a live bonsai in a large scale dio. I often find good 'trees' in old hedgrows. Boxwood is good-cheaper than bonsai.
                  My first effort at making barbed wire, after striping out lots of copper wire & finding it to stiff to work with i gave up trying, so sat down scratching my head thinking what i could use insted then BINGO it hit me try solder flex well im buggerd it worked, what u think.
                  [ATTACH]25621.vB[/ATTACH] [ATTACH]25622.vB[/ATTACH][ATTACH]25623.vB[/ATTACH]
                  [ATTACH]25627.vB[/ATTACH] [ATTACH]25628.vB[/ATTACH]
                  [ATTACH]31804.IPB[/ATTACH]
                  [ATTACH]31805.IPB[/ATTACH]
                  [ATTACH]31806.IPB[/ATTACH]
                  [ATTACH]31810.IPB[/ATTACH]
                  [ATTACH]31811.IPB[/ATTACH]
                    Nice job on the barbed wire john..... very nice indeed.
                    scott
                      [ATTACH]25667.vB[/ATTACH][ATTACH]25668.vB[/ATTACH][ATTACH]25669.vB[/ATTACH][ATTACH]25670.vB[/ATTACH]
                      [ATTACH]31840.IPB[/ATTACH]
                      [ATTACH]31841.IPB[/ATTACH]
                      [ATTACH]31842.IPB[/ATTACH]
                      [ATTACH]31843.IPB[/ATTACH]
                        Just started the body of the figure, i need him ti lean forward a little so the first pic is of the torso befor i cut it.
                        [ATTACH]25782.vB[/ATTACH]
                        This pic is of the wedge shape i cut out tomake the figure lean forward.
                        [ATTACH]25783.vB[/ATTACH]
                        Then i cut across the back the glued back together the front, this then puts the V-shape cut to the rear.
                        [ATTACH]25784.vB[/ATTACH][ATTACH]25785.vB[/ATTACH][ATTACH]25786.vB[/ATTACH]
                        Once the clue has set i place mesh inside the figure to reduse the amount of filler needed to fill the gap, once this has set its just a matter of sanding down.
                        [ATTACH]25787.vB[/ATTACH][ATTACH]25788.vB[/ATTACH][ATTACH]25789.vB[/ATTACH]
                        hope u like.
                        [ATTACH]31907.IPB[/ATTACH]
                        [ATTACH]31908.IPB[/ATTACH]
                        [ATTACH]31909.IPB[/ATTACH]
                        [ATTACH]31910.IPB[/ATTACH]
                        [ATTACH]31911.IPB[/ATTACH]
                        [ATTACH]31912.IPB[/ATTACH]
                        [ATTACH]31913.IPB[/ATTACH]
                        [ATTACH]31914.IPB[/ATTACH]
                          This will be my last post for this Dio untill it's finished and it will come with a storeyboard to explane the setting.
                          [ATTACH]25969.vB[/ATTACH][ATTACH]25970.vB[/ATTACH] This is the right arm, i needed to cut off the hand so i could put it where i needed it.
                          [ATTACH]25971.vB[/ATTACH] [ATTACH]25972.vB[/ATTACH][ATTACH]25973.vB[/ATTACH][ATTACH]25974.vB[/ATTACH][ATTACH]25975.vB[/ATTACH] This is the torso partly finished, the cloth showing will be painted camo as the uniform is reversible.
                          enjoy
                          [ATTACH]32077.IPB[/ATTACH]
                          [ATTACH]32078.IPB[/ATTACH]
                          [ATTACH]32079.IPB[/ATTACH]
                          [ATTACH]32080.IPB[/ATTACH]
                          [ATTACH]32081.IPB[/ATTACH]
                          [ATTACH]32082.IPB[/ATTACH]
                          [ATTACH]32083.IPB[/ATTACH]
                          • spanner570
                            • 15385
                            Now that's what I call one big terminal wound!!!!!!!
                            Nice one John.
                            Don't stop the pictures though, eh?
                            Ron
                              Thanks Ron, all looke a bit rough at the moment but it's coming together slowly.
