First Diaorama Attempt - Car MOT Garage - Work in progress!
    I haven't been on the forum since last year (I haven't had time to make any models etc due to moving house & other bit's and bats!) And I'm relatively new to modelling - I've done a few 1/24 plastic kits, which I have posted on the forum before.
    Anyway... I've decided to have a go at making a diorama, using balsa and lollipop sticks. Here's what I've done so far (step by step) - honest opinions please!
    (The flat roof is going to be boarded, probably using lollipop sticks, with the rounded ends cut off, then I'm going to use firestone rubber as the roof covering. The pitched roof is going to be boarded also, then I'm using my cut-off lollipop stick ends as roof slates. The gable ends will probably be 'cladded' in lollipop sticks like the rest of the building. The garage walls will most probably be corrugated card, unless I think of anything better. That's as much as I've planned so far)
    [ATTACH]68674.IPB[/ATTACH]
    [ATTACH]68675.IPB[/ATTACH]
    [ATTACH]68676.IPB[/ATTACH]
    [ATTACH]68677.IPB[/ATTACH]
    [ATTACH]68678.IPB[/ATTACH]
    [ATTACH]68679.IPB[/ATTACH]
    [ATTACH]68680.IPB[/ATTACH]
    [ATTACH]68681.IPB[/ATTACH]
    [ATTACH]68682.IPB[/ATTACH]
    [ATTACH]68683.IPB[/ATTACH]
    [ATTACH]68684.IPB[/ATTACH]
    [ATTACH]68685.IPB[/ATTACH]
  • aaron
    • Oct 2011
    • 2019
    Nice frame...Great ideas for the roof.
      Thanks Aaron!
      I've been looking at alsorts of "roof coverings" for modelling on eBay, but have only either found packs of single roof tiles (which are too expensive), or tiles just printed onto self-adhesive paper, which will probably look awful on it. The lollipop stick ends will probably match in best, and look great. (hopefully!)
        Card cut into tiles or similar works well, just size them to the scale you're working on.
        Corrogated roofs look good, you can make them out of tin foil or use the rippled card from some fast food packaging.
        I've used both... don't like posting my work on others threads so have a look at my started threads (mash and coutance have roofing in particular)
        I did a Korean workshop and scratch built most of the tools in that to maybe spark an idea for you.
        Ron (spanner) has done some great 1:72 buildings and its well worth browsing through those, in fact I've nicked some of his ideas in mine but don't tell him
        Hope the above helps in some way.
        • eddiesolo
          • Jul 2013
          • 11193
          Good work on the frame and the cladding. Nice build so far.
          Si
            I'll have a look at them now Colin - thankyou for the ideas! I think I'll make my own tiles (or should I say shingles?) from the lollipop sticks, keeping in theme with the wooden frame etc. Might give the foil on corrugated card idea a go for the flat roofed portion's exterior walls.
            Thanks Si! It's appreciated
              Sorry me being quick and ignorant there .....
              Omitted to mention that I like the progress so far, looks a good solid platform to build on.
                Very nice build so far.
                This garaje will give you a world of possibilities for weathering
                  Cheers Colin!
                  Thanks Polux - I've never actually attempted weathering before now, even though it's something I've always wanted to have a bash at with my 1/24 cars. I'll definitely be experimenting with this though!
                  Just boarded the flat roof now..... Once this sections had it's walls cladded I'll be able to put my rubber roof on!
                  [ATTACH]68691.IPB[/ATTACH]
                    You could simulate a felt roof with some medium wet&dry, just give it a wash with some darkish green then give it a dry brush with a mid brown and it'll all blend in nicely.
                      That sounds like a good idea Colin - haven't got any wet & dry though, and got plenty of cut offs of Firestone rubber from work
                        Oooh bargain ... set to it then young man (and don't forget the piccies)
                          I've started work on the pitched roof first as I'll need to clad the other section before doing the rubber roof (I'm having a Chinese tonight, so hopefully some worthy materials might come from that haha)
                            Ok guys - quick progress update!
                            Started slating the main roof, ordered myself some corrugated card off eBay for the remaining walls, since the Chinese didn't send me anything worth using haha.
                            [ATTACH]68713.IPB[/ATTACH]
                            [ATTACH]68714.IPB[/ATTACH]
                            Opinions? I just used normal card to support the 'slates'.
                            BIG PROBLEM now though..... running out of glue!! So won't be getting much more done tonight
                            • flyjoe180
                              • Jan 2012
                              • 12381
                              • Joe
                              • Earth
                              Looks amazing Curtis. Fantastic idea for a diorama, watching with interest.
