Simple, cheap diorama base (hints, tips and tricks)
    After speaking to one of our leaders, Ian (M) said it would be better to post this here as opposed to the "how to" forum as i'm eventually going to use it as another Korean diorama in the new year.
    Soooo.
    There's been quite a few people thinking about diorama bases for their models, a lot of them have said they wouldn't know how or where to start. A few have said that its expensive to get the stuff so I thought I would do a diorama base that incorporates rocks, trees, bushes gravel tracks and most of the little bits that make up a base ..... And do it all on a cheap budget just to show you don't have to go spending mega-bucks to build one.
    This is by no means the definitive on diorama bases, and i'm not implying i'm a master at the things, but i have been asked a couple of times to do a step by step to show how i get my own look.
    There's others on here that create brilliant dios and i hope they'll chip in with some interesting info along the way
    The base:
    An old photo frame 18x14 ins, glue the back on so you have a solid platform to go at.
    some old polystyrene inserts from packaging is used as the base for the rocky outcrops, i glue them on with PVA
    [ATTACH]72605.IPB[/ATTACH]
    [ATTACH]72606.IPB[/ATTACH]
    Use a mini bunsen or ciggy lighter (on full bore) to melt the poly into a more rounded/erratic natural look
    [ATTACH]72607.IPB[/ATTACH]
    Add some clay/Plasticine (or real stones) and texture it with anything to give a rough(ish) natural look
    [ATTACH]72608.IPB[/ATTACH]
    [ATTACH]72609.IPB[/ATTACH]
    [ATTACH]72610.IPB[/ATTACH]
    [ATTACH]72611.IPB[/ATTACH]
    Next i mixed up some cheapo poly filler and smeared it all over the floor, any left over i filled in some cracks in the rocks and added blobs of filler here and there which will look like extra boulders and/or smoothed off stone.
    I dragged my fingers through the poly filler to simulate the divots in the mud/sand/gravel that would be made bu vehicles driving through.
    [ATTACH]72612.IPB[/ATTACH]
    [ATTACH]72613.IPB[/ATTACH]
    [ATTACH]72615.IPB[/ATTACH]
    when dry i painted the rocks a mid grey and just highlighted some edges with a brown - you'll be surprised how much this will add to the natural look when the black wash is thrown over.
    The roadway has been painted brown and the areas where there's going to be grass/greenery has had a green painted on, this gives a background to the substrate/scatter/grass that will be added giving that bit of "depth"
    [ATTACH]72616.IPB[/ATTACH]
    Next up ... adding the ground work... thanks for watching
    [ATTACH]72614.IPB[/ATTACH]
    [ATTACH]72617.IPB[/ATTACH]
    Excellent, looking forward to following this, can never get enough info and tips.
    Tom
    • geegad
      • Mar 2010
      • 2329
      i thought the first few you was going to turn it into a side of a church or building..like the rocky out crop idea very nice
        Brillant Colin!!
        I'll be watching this one with interest mate
        Polux
        • eddiesolo
          • Jul 2013
          • 11193
          I love doing dios, and have made some nice playboards for Warhammer, these have been expensive in some materials and not in others, as you say, sand, polyfilla, herbs and spices for foliage and debris, papermaché, old bits of model kits, you name it anything will do. I used to buy the large sheets of 3mm MDF board from B&Q for a tenner, loads of boards can be made out one sheet.
          Save everything and use everything. Great showcase of what can be made with just a few items and on a cheap budget, nice work Colin.
          Just to add this could be a nice challenge. Build a basic dio board from what you have or have found/picked up without buying anything else in especially for the board.
          Si
          • eddiesolo
            • Jul 2013
            • 11193
            Originally posted by \
            I love doing dios, and have made some nice playboards for Warhammer, these have been expensive in some materials and not in others, as you say, sand, polyfilla, herbs and spices for foliage and debris, papermaché, old bits of model kits, you name it anything will do. I used to buy the large sheets of 3mm MDF board from B&Q for a tenner, loads of boards can be made out one sheet.Save everything and use everything. Great showcase of what can be made with just a few items and on a cheap budget, nice work Coilin.
            Si
            • Richi72
              • Sep 2013
              • 1100
              Hey Colin I am all over this one.
              cant wait for the next lesson.
              Cheers Richi
              • Gern
                • 9211
                Now I see what you mean about melting your poly to make rock shapes. When I tried I used some tiny little pieces and it went all 'orrible. Have to have a go with some bigger pieces 'cos that looks really effective.
                Gern
                • monica
                  • Oct 2013
                  • 15169
                  nice work ,always interested in how , and what other people use in there diorama bases,
                  will be keeping an eye for more post, i would like to see you do the trees and shrubs in this one,
                  moni
                  • spanner570
                    • 15383
                    Colin, to use that awful Colonial expression....'You have all the bases covered'
                    A good, informative thread.
                    Thanks for taking the time to post it.....
                    Ron
                      Thanks very much for the support and comments people.
                      Si ... Railway and warhammer and D&D bases ..... Made a few over the years.
                      Dave ... Glad the piccies made it clearer about attacking it with a flame.
                      Monica .. There'll be bushes and trees added in part three and I'll attempt to explain how and what was used to achieve them.
                      Ron ... Please chirp in if you have an alternate or better method for owt OK mate.
                        I've done a few over the years and found that picture frames were a great place to start. The thing I have always come back to though with a base or a diorama is regularly to keep it simple. Even a thick coat of PVA glue with sand poured onto it looks very effective when set and the excess poured off. A couple of stones from the garden gives a bit of volume and you can quite often get away with nothing more than that as a base. If you want to develop it into a diorama you have a useful foundation to build on or you can just leave it as a base.
                        Great tutorial though and always good to see other techniques and ideas.
                        • eddiesolo
                          • Jul 2013
                          • 11193
                          I always remember being told that the main thing with a dio or a stand alone piece on a board is planning, just a few items can set the object off, too many can spoil it and detract from what you really want to show. However, as you learn and get more comfortable in doing boards then you can add all kinds of things, loads in fact but you will learn how to place them so that they 'add' to the piece.
                          Si
                            That's what's drying at the mo pictures tomorrow.
                            Thank you Richard.
                            • eddiesolo
                              • Jul 2013
                              • 11193
                              Me too lol, doing the Triceratops base. Just added some glue and fine grit mix, it be drying as we speak...well type.
                              Si
