"ATTACK!" Chancellorsville...May 2nd,1863
  • saguy
    • Feb 2011
    • 570
    #31
    this should be good ...... very different .....
    • monica
      • Oct 2013
      • 15169
      #32
      great work Ron do like this one a lot , as its been said, simple cheap and looks fantastic, real nice
      paint work on the horses, did you use oils ? as they have a real death to them , may i ask what changes
      you made to them ? the little guys came out well also , see your not harsh with weathering like me
      will be keeping an eye on this
      • spanner570
        • 15402
        #33
        Originally posted by \
        great work Ron do like this one a lot , as its been said, simple cheap and looks fantastic, real nicepaint work on the horses, did you use oils ? as they have a real death to them , may i ask what changes
        Thanks Monica, the paints are Vallejo Model Colour, brush applied.
        I changed the two falling horses front legs and tucked them under the bodies. The horse to the left, I changed it's neck and head to make it look twisted as it hit the trench floor, I altered the jumping horse to make it rear up a bit. One thing I did notice....Real horses don't bend much in the middle!!!
        The troopers arms were altered a wee bit to suit a falling attitude and the middle one had his torso twisted for the same reason.....
        Thanks for the questions.
        Ron
        • monica
          • Oct 2013
          • 15169
          #34
          you did a real good job off it,cannot even tell, from the pics ,
          your right they dont bend much in the middle as i did dressage for years,
          and is tricky to get a model to look as its moving right,well done
          did you just cut,pin with wire to bend to shape and then fill ?
          • spanner570
            • 15402
            #35
            you did a real good job off it,cannot even tell, from the pics ,your right they dont bend much in the middle as i did dressage for years,
            Thanks Monica....
            I just cut the joints with a modelling knife, filed and butted the joints together in the new position and then glued them. I used Humbrol Filler for the gaps in the joints and then sanded them smooth......No wires.
            Ron
