The Old Neon Sign.
  • monica
    • Oct 2013
    • 15169
    #46
    looking very good Polux keep up the good work
      • 18271
      I would make a smaller sign that said Est. 2004 (Est. = established) Polux.
      I have a couple of questions, Do you own a laser printer or one you can use? It only need be a Black printer, but has to be a laser one....
        Interesting method Polux and letters are big than i thought.
        My vote for option A.
        Francesco
        • John
          • Mar 2004
          • 4646
          • John
          • Halifax
          #49
          Originally posted by \
          I hope to correspond at the confidence that John gives me, so I will do it with my best effort!!!
          Thanks
          Polux
          Polux, I've been keeping an eye on this thread and I have every confidence in your ability to create a great piece of work, looking good so far.
          www.scalemodelshop.co.uk
            I would make a smaller sign that said Est. 2004 (Est. = established) Polux.I have a couple of questions, Do you own a laser printer or one you can use? It only need be a Black printer, but has to be a laser one....
            The "established" is a nice idea...and can be for always!
            I have one, but it's not laser.... Anyway I can try to find somewhere that can use one O_o
            Tell me... :P
              Thank you very much John!!
              Just don't be despair with my slow work... :P
                • 18271
                I have a mate that does this neat trick when he needs accurate marking for cutting out plastic card or even plywood. He builds model ships.
                He copies the plans onto the computer and opens it in a picture program. Then he takes the part he need, and reverses the image so he gets a back to front picture. He prints that out on a laser printer.
                Here's the smart bit, Put the image print side down on the plastic card and then using an iron (ask the wife what one of those is). Carefully heat the back of the paper by running the iron over it. The heat from the iron will transfer the "ink" from the print to the plastic. Carefully remove the paper and.... Da daaaaaaaa. the plan is now transferred to the plastic and is the right way round.
                As I say, it need only be black and white, but you can use colour as well. Black for cutting, red for fold in, green for fold out, you can even use say yellow for where other bits need to be stuck...
                  That is an absolutely nice tip Ian. Have to try it
                  Anyway is a corious thing, the laser ink be most weak at heat, than the normal one....
                  You give an idea for my next build :P Thank you !!
                  Polux
                    Coming along nicely there
