Well, what is there to say...this is becoming, in my view, your best work so far. Quality build and staging, and all knitting together perfectly. Very well done Al.
hi Alan maybe not the right time to ask, but re looking at the guys, how did you get the insigne , to stand out so well, ?Im using mr color silver , but it dose not stand out like how yours dose, ummm that kind off sounds wrong
any handly tips, when using field blue and green please ?
Hi Moni I used either Vallejo model colour natural steel or revell aqua colour silver 90, I can't remember which now
As for field blue and green sorry I can't help really
To me Al, it looks more worn than hasty. I rather like it, what you could do is add some home made camo splashes-some green-roughly applied to give the impression of maintenance area/crew commander getting hold of some paint and trying to get his tank to blend in a bit more.
Cheers Si , worn hastily painted works both ways for the story , and I'm already ahead of you with the camo , this is just the start I wanted to see if it would look right and I like it but would it pass the test is what I wanted to know
Try using a cotton bud and then streaking the paint on the tank, once nearly dry take a hard brush and drag-this should give the impression of paint slapped on quickly.
I agree with Si & also the basecoat is applied at the factory so it wouldn't be hastily applied.The camo is often done in the field so that would work.
Patrick
Your spot on Patrick as I have just mentioned it works both ways in the story so I'm pleased with that
