Don't know if it helps Alan, but I use mixed herbs (£0.49p in Tesco) for leaves & I spray the tree/bush with basic hairspray and then sprinkle the herbs over it - works a treat!
[ATTACH]79933.IPB[/ATTACH]
Hopefully you can see what I mean on my Jagdpanther.
that is a very nice tree Alan, starting to take shape , and like how you have use a real bit off stick,if you are finding that the PVA takes a bit to long to set,
as I did, use UHU drys quicker and dose dry clean, and can be painted over, once you find that there is all the foliage you like then use the hairstick to
add darker on the underside and lite on the top ,just sprinkle buy your fingers or use a shaker, what i did was make one from a coffee jar the big one and drill
No 30 hole very close together, to shake out the foliage
must say Patrick that the branches on your Jagdpanther. worked out very well with mixed herds great job
that is a very nice tree Alan, starting to take shape , and like how you have use a real bit off stick,if you are finding that the PVA takes a bit to long to set,as I did, use UHU drys quicker and dose dry clean, and can be painted over, once you find that there is all the foliage you like then use the hairstick to
Thanks Moni I appreciate that also thanks for the tip I do have some course turf in a lighter colour and I was going to sprinkle that on with my fingers but the coffee jar idea sounds much better
That looks fine Alan, the camo is excellent. I wouldn't worry too much about the camo pattern - every reference I've seen shows subtle differences because vehicles came from the factory in Dunkelgelb & the crews applied the Olivgrün / Rotbraun themselves.
