hello all thank you all for dropping bye, and for the real nice comments i do appreciate so much well got some time in today, and finished the ruin shed and roof
It's really amazing how much skill you have in creating these dioramas Moni! Every one I've seen has been painstakingly crafteduntil it's perfect.
I don't really go for large dios like you & Ron do, but there's a lot of great tips to be found watching how you make stuff.
thank you Patrick, its all the nice comments from your shelf and the other lads that keep you going and to do your best work,
ta Ron i do have some spare for that and also the wall and thank you for your tip an easy thing to for get plus save some of the color as well,
hi Scott yes it is balsa cut into strips of 12mm W x 15mm L x 1.5 mm T, with just the corners nipped off the fronts, then stuck down with pva glue, with an overlap of 5mm,
