"There's an old mill by the stream, Nelly Dean!"
    Wow!!
    This is coming along very nicely Ron
    A master piece is genial
    • Alan 45
      • Nov 2012
      • 9833
      #152
      Originally posted by \
      Not a bad idea, Ian......on the scale of things it sounds a bit fishy!My coat is on, firmly buttoned up and I'm out the door.......
      Ron I cod'nt believe you just said that
      Do you fancy sharing a taxi :P
      Looking good mate now I know what to do for my rock face cheers
        Amazing you keep improving it every time I think you can't improve on that there you go and do it again
        • eddiesolo
          • Jul 2013
          • 11193
          #154
          Oy Si, have you been reading my script? That's stage two! Good tip to pass on nonetheless.....
          It is so well set out, that this has to be by a script, not just slapped on and hope for the best.
          Si
          • monica
            • Oct 2013
            • 15169
            #155
            Looks amazing Ron. real lov it, as said each update is such a improvement, that water is great,
            one thing i find is with using coffee stirrers., is that there so hard to cut, even with a sharp blade
            great tips for the use off silicone like that idea, ta
            • spanner570
              • 15436
              #156
              It is so well set out, that this has to be by a script, not just slapped on and hope for the best. Si
              Honest Si, all I had was a base and I knew I wanted to do a mill wheel. The rest was, or is, totally unplanned....I just wait for ideas to come along, I can't work any other way.......!
              So far it's worked......
              • eddiesolo
                • Jul 2013
                • 11193
                #157
                Honest Si, all I had was a base and I knew I wanted to do a mill wheel. The rest was, or is, totally unplanned....I just wait for ideas to come along, I can't work any other way.......!So far it's worked......
                And worked very well it has.
                Si
                • spanner570
                  • 15436
                  #158
                  Quote="monica, post: 212594, member: 24381"]one thing i find is with using coffee stirrers., is that there so hard to cut, even with a sharp blade
                  /quote]
                  Monica, I have found the best way to cut these stirrers is.....
                  Always use a metal rule or straight edge - never plastic, bye bye fingers!
                  Use two stirrers, one you are cutting, the other sits under the rule to keep it flat, and not at an angle as just one would be....I hope that makes sense.
                  Don't try and cut through in one go. Gently scribe a line with your knife, pressing down firmly on the rule. Keep fingers behind the blade!
                  Keep repeating - the knife will follow the line and gradually cut through and not wobble off.....
                  • eddiesolo
                    • Jul 2013
                    • 11193
                    #159
                    Quote="monica, post: 212594, member: 24381"]one thing i find is with using coffee stirrers., is that there so hard to cut, even with a sharp blade /quote]
                    Or I use the knife or a small pair of modellers snips. And yes, I am allowed to use sharp objects...my care-worker says I can. :P
                    Si
                    • monica
                      • Oct 2013
                      • 15169
                      #160
                      ta Ron that is a good tip for cutting them and thats what puts me off using them as i like my fingers,
                      thats a good tip as well Si ta, i think i try to rush cutting them abit so not a good thing,
                      • spanner570
                        • 15436
                        #161
                        ta Ron that is a good tip for cutting them and thats what puts me off using them as i like my fingers, thats a good tip as well Si ta, i think i try to rush cutting them abit so not a good thing,
                        Just a quick add-on Monica...For cutting across the stirrer, I don't use modelling snips. I use a pair of electric cable cutting snips. I don't think the modelling ones are up to the job, best keep those for delicate sprue work!
                        • Gern
                          • 9226
                          #162
                          Have you tried this Alan?
                          http://www.ebay.co.uk/itm/LOreal-Men-Expert-Vitalift-5-Moisturiser-50ml-/131150124146?pt=UK_Health_Beauty_Skincare_PP&hash= item1e89281472
                          Gern
                          • monica
                            • Oct 2013
                            • 15169
                            #163
                            i did not even think to use them always just try dragging the blade across great idea ta,
                            • Alan 45
                              • Nov 2012
                              • 9833
                              #164
                              Have you tried this Alan?http://www.ebay.co.uk/itm/LOreal-Men-Expert-Vitalift-5-Moisturiser-50ml-/131150124146?pt=UK_Health_Beauty_Skincare_PP&hash= item1e89281472
                              Gern
                              Cheers Dave I'll have to get some , can you apply it by brush
                              • spanner570
                                • 15436
                                #165
                                Alan, as it's your mush, I suspect it would have to be the wire variety!!!!!
