do you work off any real size for the stones or just what you think looks ok for your scale ?or not so import for stone , but more necessary for bricks
Sorry Monica, I forgot to answer you question........
I just make the stone to what I think looks right, but you are right, bricks have to be the right scale- which is why I hate 1/72 bricks, hence my preference for stonework!
The only reference I use for making buildings is to get a doorway the right scale, and then I just make the rest to look in proportion.
Wow the bridge turned out great! The footbridge is fantastically simple and effective , as for the wheel, I'd say that's your choice, I couldn't make up my mind
Thanks for all your encouraging posts, they make for great reading.
Thanks for the input regarding the wheel - dead or alive? It looks like it's a working wheel simulation then..It won't be actually moving, just giving the impression of movement...I hope!
Rather than do a bit more to the buildings, I have made inroads into the shaping of the river bank and the water itself. This can then be going hard whilst I do a bit more to the structures....
For this I used tile adhesive, but anything suitable can be used....polyfilla, plaster or anything similar.
Here's the 'Before', complete with that plunge pool! I've given the white polystyrene a coat of brown paint.
[ATTACH]82614.IPB[/ATTACH]
...and the application of the adhesive to add some shape to the river bank, smooth the river bed and salmon steps out a bit, also generally fill in any unwanted holes......
[ATTACH]82615.IPB[/ATTACH]
[ATTACH]82616.IPB[/ATTACH]
Also a bit of work down stream......The bridge is still a loose fit.
[ATTACH]82617.IPB[/ATTACH]
We need a sluice gate to divert the water into the mill race. I made this from coffee stirrers and copper wire from some old electric cable.
Again I've tried for that rustic look and also cut some notches into the mechanism.....
[ATTACH]82618.IPB[/ATTACH]
and weathered......I've modelled the sluice open, so no turning back now, the water is pounding down the mill race!
[ATTACH]82619.IPB[/ATTACH]
Loosely fitted, ready for more painting etc.
[ATTACH]82620.IPB[/ATTACH]
[ATTACH]82621.IPB[/ATTACH]
Next it's a bit more work on the river bed and also adding some more colour to it.
I hope you approve of progress thus far, and enjoying seeing it come to life....I'm getting a bit of a buzz on for sure!lol
I've tiled the mill roof...As I've gone over my way of doing this on previous builds, I won't bore you again!lol Suffice to say I still make my tiles / slates in a single strip.
Here is the roof ready for painting. I purposely dipped the ridge line to make it a bit more sagged and old looking. Also, I am never fussy about getting the tile lines just so....it's an old building.
[ATTACH]82898.IPB[/ATTACH]
I've started work on the stream. I use paints to convey depth to the water....Light to the edges and getting darker to the middle. This gives a sort of illusion of depth.
[ATTACH]82899.IPB[/ATTACH]
Here a second darker coat has been added to the deeper middle.
[ATTACH]82900.IPB[/ATTACH]
Here's two more views - before and after.
[ATTACH]82901.IPB[/ATTACH]
You can just see the painted roof too....It looks bl***y awful and constantly takes the eye away from the wheel etc. I really don't know why I painted it like that....Logic says it should be about the same shade as the surrounding stone - Locally made and all that! Time to re-paint!
[ATTACH]82902.IPB[/ATTACH]
This is the lower mill race and stream. I've tried to show how the race has scoured out the stream bed. Also the stream is deeper on the outer edges of the bend caused by the water always running quicker in this area.....
[ATTACH]82903.IPB[/ATTACH]
You might remember that very early on in the build I removed the left hand side of the building. Here I have made another building and this will be stepped back from the mill, but attached, making a kind of dog leg, which I hope will help balance to frontage a bit better. Some might recognise the design - It's the derelect farm from my Group build 'Flush him out!' I always keep the paper templates, so I was able to more or less copy the same building again....
[ATTACH]82904.IPB[/ATTACH]
I'm not too sure about this building, it might be a bit too big and dwarf the mill. I'll glue it together and see......
Ive been piking through a knot hole in the fence at this one matey, I'm just amazed at the whole thing . Its a superb exercise in scratchbuilding and ingenuity , like most of your builds. Its a pleasure to watch ,I just hope i get to see it in the flesh sometime. Looking forward to seeing the water effects go on , cheers tony
