Horrible faces
  • KarlW
    • Jul 2020
    • 1522
    Horrible faces
    OK so I decided to give painting a bust another go, something I've wanted to do for a while, as my stash will attest, but I have some sort of mental block.
    I decided to do this 95th Rifles bust from sovereign but the eye's are as horrible as they look on the box art, I can't tell where the eye is actually meant to be.
    Though the right side if the face does look a bit swollen so I wonder if it's meant to be swollen shut......
    How do you cope with poor sculpts on faces? New head, resculpt, bin?
    One part of me wants to soldier on and not worry about the eyes, another part is saying bin it
  • SimonT
    • 2824
    I wondered if he was meant to be squinting in the hot Spanish sunshine :thinking:
    I decided to re-sculpt mine - it would have to be really really bad before I binned anything before having a go at fixing it
    this is modelling
    photo above for inspiration - drilled out the sockets and installed ball bearings then sculpted detail over the top
    turned out not too bad and painted up ok
    give it a go
    • Gern
      • 9301
      I don't do large figures Karl, but I'd be interested to see the actual figure. I was talking to Tim the other day about poorly cast 28mm metal figures and I'd just like to see what you guys have to cope with on the larger ones.
      • KarlW
        • Jul 2020
        • 1522
        I did try putting a wash over the area to show the actual thing but it didn't take to the bare resin and I am replacing some detail on the torso.
        • Steve Brodie
          • Sep 2014
          • 4652
          Thats a cool idea
          • Jason Crausby
            • 658
            Hi Karl
            its not a problem I’ve come across that much but if something is badly sculpted I don’t think any expertise in painting can put it right... I know Peter D will often use different heads if he’s not happy with one but I’m not sure if they are readily available in that scale.???
            As you said you were trying out doing busts again maybe you should find one that your happy with the sculpt as a bad experience could put you off?
            I have mainly done busts recently and like working at that scale but if I wasn’t happy with the sculpt I suspect it would stay on the shelf.
            Jason
              Hi Karl. These sovereign busts don't have a great reputation I'm afraid, the faces in particular being pretty poor. I would probably try replacing it with a spare - reedeesminiatures.co.uk have some heads in 200mm which fir 1/9 and 1/10 scale busts. You could chop the shako off and use that with the new one.
              • KarlW
                • Jul 2020
                • 1522
                I'll have a look at those heads, cheers.
                For now I've decided this will go back in the box, even though I have done some work on the torso, I got rid of that unconvincing tear on the right shoulder and replaced the cord for the powder horn, it was damaged on arrival but was horribly sculpted anyway. It got shaved off and replaced with a Tamiya towcable, not quite correct but better.
                • Richard48
                  • 2166
                  • Richard
                  • Clacton on Sea
                  He certainly has some dodgy peepers indeed.Short of re.sculpting eyes then new bonce like the guys advised.A real shame for you but some spare Reedees heads could prove useful for future.
                  Onwards and upwards chap.
                  Rich.
