Bravely attempting a set of 28mm figures....
Tags: None
Hi Gavin. They look nice. Good luck with them…….but don’t destroy a brush. Small brushes with few hairs do not help with detail painting. They dry up too quickly and don’t let the paint flow. A brush with cut down hairs will never hold a point either. To get good sharp detail you need properly thinned paint and a good quality brush with a sharp tip. I’ve done loads of 28s over the years and my “go too” brush for almost everything on the figure, including eye balls, is a number 1 sized brush. -
Hi Gavin. They look nice. Good luck with them…….but don’t destroy a brush. Small brushes with few hairs do not help with detail painting. They dry up too quickly and don’t let the paint flow. A brush with cut down hairs will never hold a point either. To get good sharp detail you need properly thinned paint and a good quality brush with a sharp tip. I’ve done loads of 28s over the years and my “go too” brush for almost everything on the figure, including eye balls, is a number 1 sized brush.Comment
AndyComment
Yeah I know! I wasn't expecting much when I bought them, never even heard of the manufacturer because they're not a big name or anything. But the quality and detail is arguably the best I've ever seen. Definitely recommended. GComment
RichardComment
You're welcome indeed. I'm quite enjoying this scale thus far, there is a lot less surface area to paint than the Tamiya 1/16 scale figures! GComment
