Advice regarding a battle flag....
  • Gavalaar1980
    • Aug 2020
    • 484
    Hi folks,
    This Confederate 54mm officer figure kit (see photos) caught my attention online, so I bought it. However, just noticed the battle flag will need painting, I was kinda mistaken here and expected the kit to come with an actual miniature fabric flag!!
    [ATTACH]468863[/ATTACH]
    [ATTACH]468864[/ATTACH]
    So would my question is would you paint the flag and if so, how? (Mask it up and cut away the cross etc? The flag has an undulating surface for realism which isn't flat, making painting harder still). Or would it be wiser to source an actual miniature scale flag (this would look much better in my opinion) if such a thing exists?
    Kind regards,
    Gavin.
    • 18257
    I might find a nice thick foil, (the foil from a wine bottle was great). Cut it to size, paint the flag then carefully arrange it so it ripples.
      Gavin,
      I'd think you would be better oof with a decal, or at a pinch a printed fabric flag, but if you have to make your own.................
      Good Luck!
      • Gavalaar1980
        • Aug 2020
        • 484
        Thank you, will bear this in mind if I have to make my own. G
        • Airborne01
          • Mar 2021
          • 3934
          • Steve
          • Essex
          Where do you live Gavin? I have a (~2x2") piece of lead foil from Historex which was intended for such purposes - if you're stumped then I'll post it to you gratis. PM me if you want it.
          • Gavalaar1980
            • Aug 2020
            • 484
            Gavin,
            Good Luck!
            Thanks for that Dave. I've basically got 3 options here:-
            1. Use a decal that's the exact size.
            2. Buy an actual miniature flag and make it fit somehow.
            3. Make one from scratch from foil and paint it.
            I think that painting the flag free hand will just be a disaster and out of the question because it hasn't even got the detail engraved on the moulding for the cross etc, so it just wouldn't look right.
            Cheers. G
              • 18875
              There are several manufacturers out there making printed 54mm (I assume he’s 54mm) replacement flags, but personally, I would try to paint the supplied flag freehand first……..it’s easier than you think and it will match the style of your painting on the rest of the figure.
              There are a lot of tutorials out there, so have a good look around. Don’t overlook the warhammer stuff, there are some great painters working in that genre.
              Look at references to get the colours right, as both the flag and the uniform on that box art look a bit insipid. if you can’t find any, let me know I’ve got quite a few books on ACW uniforms and flags and will post something if you want.
              As a start I personally would paint the background colour, then pencil in the cross using a sharp soft pencil. Use pencil because pencil lines won’t run when overpainted. If you make mistakes, just paint out the errant lines and have another go. would then paint it in the light outline colour, using the pencil lines as guidance. It is easier to paint thin lines by painting up to en edge, so then paint the blue inside that, cutting the light colour to size as you go. At all stages painting over mistakes can sharpen up the finish. Lastly pencil in the stars and paint them in when you are happy…..
              • Gavalaar1980
                • Aug 2020
                • 484
                Hi Steve,
                I'm in Norfolk. Many thanks for the kind offer, I shall bear this in mind if I decide to make my own from foil.
                Regards,
                Gavin.
                • Gavalaar1980
                  • Aug 2020
                  • 484
                  Hi Tim,
                  Okay, it's possible to paint the flag part free hand. That's a fair test of skill but hey, that's what we want eh?! ☺ Thanks for the tips (painting the background colour then pencil in the cross etc), makes sense how you've described it.
                  For paint colours I will need to source the nearest Vallejo shade to the Confederate grey/light blue and the flag background (an orange/red shade?), everything else I should already have.
                  Thanks. G
                    • 18875
                    Don’t stress over it Gavin. It is basically a combination of brush control (which you already have), and planning. The worst than can happen is you have to strip it and start again…..it’s just pushing paint around with a brush.
                    Colours, I’ll check my sources and get back to you……probably tomorrow.
                    • Gavalaar1980
                      • Aug 2020
                      • 484
                      Great advice Tim, I did indeed paint the supplied flag as you advised, here is the end result!
                      Many thanks for your tips. G
                        • 18875
                        Excellent work Gavin. Looks far better than any paper print would. Should have given me a nudge though….I completely forgot to look up colour references for you. Turns out you didn’t need them anyway. Those colours look spot on :thumb2:
                        • Gavalaar1980
                          • Aug 2020
                          • 484
                          Thanks Tim, and no worries, we're all mega busy this time of year! The flag was a real challenge to paint, very tough getting it spot on....
                          Cheers. G
                            • 18875
                            Great feeling when you nail it though isn’t it :thumb2:
                            • Gavalaar1980
                              • Aug 2020
                              • 484
                              Sure is yeah, the satisfaction is really something else! It's why we do what we do....
