Latest Acquisitions (2019)
Well heres my modest haul
The eduard Yak 3 was £2 ! No instructions , decals , pe and missing the propellor spinner but im sure i can supply these from my spares. The siege machines is just so nuts i had to have it and it was £4 so this is one of the candidates for the under a fiver build. The Revell f-18 was £14 , looks a lovely kit , and the bandai japanese manga spaceship thing was £5 , so this might be getting done for the under a fiver build too , although i will have to brush up on my Japanese!! The flexi files and p-38 photo etch were £ 1 each , bargain!Comment
Well heres my modest haul[ATTACH=CONFIG]n1090368[/ATTACH][ATTACH=CONFIG]n1090369[/ATTACH][ATTACH=CONFIG]n1090370[/ATTACH][ATTACH=CONFIG]n1090371[/ATTACH][ATTACH=CONFIG]n1090372[/ATTACH][ATTACH=CONFIG]n1090373[/ATTACH][ATTACH=CONFIG]n1090374[/ATTACH][ATTACH=CONFIG]n1090375[/ATTACH][ATTACH=CONFIG]n1090376[/ATTACH][ATTACH=CONFIG]n1090377[/ATTACH]
Pete.Comment
my haul from Cosford
(I think I must have some Yorkshire blood in me ,Dave).....except for the first one
[ATTACH=CONFIG]n1090334[/ATTACH]
[ATTACH=CONFIG]n1090335[/ATTACH]
£5
[ATTACH=CONFIG]n1090336[/ATTACH]
£8
[ATTACH=CONFIG]n1090337[/ATTACH]
missing one trunk and one arm, but for £3 I can work with that
the next three were £2.50 each
yum!
[ATTACH=CONFIG]n1090338[/ATTACH]
[ATTACH=CONFIG]n1090339[/ATTACH]
[ATTACH=CONFIG]n1090340[/ATTACH]
a good day!
I love these airfix 54mm kits theyre so beautifully tooled , its just a shame my figure painting skills dont match the standard of sculpting. Cheers tonyComment
Evening all,
I finally made it to a show after many years absence - met some of the chaps down at Cosford :thumb2:
It would of course have been rude not to buy something after travelling all that way so.......
[ATTACH=CONFIG]n1090273[/ATTACH]
rather nice 1/48 armoured car - not seen this one before
[ATTACH=CONFIG]n1090272[/ATTACH]
some paint. There was a note on the box of paint saying £1.50 which seemed rather too good to be true so I queried if that was just for one bottle rather than the entire box. Turned out the note had fallen off the shelf above :crying:
Stall holder said "but these ones are 10% off". I picked up this set and said I would have it. "oh not that one that's Ammo not AK, that one is full price". Paints had got into wrong box!!! BUM. So the worst bargain ever at the end of the day as I had to pay full price
[ATTACH=CONFIG]n1090271[/ATTACH]
an allied lorry - bit different and not bad price
[ATTACH=CONFIG]n1090274[/ATTACH]
lastly this 72nd Hummer by a company called Military Wheels - never heard of 'em
[ATTACH=CONFIG]n1090275[/ATTACH]
for the bargain price of £4 so it just creeps into Rons 'under a fiver' category
Bought without looking at the contents - had initial viewing after I got home and it doesn't look too bad
Very enjoyable day
At least you enjoyed the day out .
John .Comment
John - the JLC006 is designed for cutting round tubing, holds it in the V shape. I have used mine quite happily for square rod and tubing as well. Only downside is it doesn't have slots for 45deg cuts
Count is spiralling out of control - I have more stock than a lot of the traders! :smiling4:
Ron - I look forward to seeing what you can do with it. That Corvette was a good bargainComment
Just think you could attend shows and become a trader if a change of career is needed .:smiling2:
Not much sleep last night then, posting this at 03.38 and again this morning on your thread !
Don't know how you do it .Comment
HI All this is my lastest a seaking chopper which I managed to get fairly cheap off ebay for 11 quid now this will be a workin model with spinning rotars an nav lights to fit on the flight deck of my now started HMS TIGER C20 build . An it will be one of four seakings as some seakings will be fitted in the hangars an should be able to be seen by havin the hanger doors open an close with light inside an I will be workin under a bit of moddeler's licence
chrisComment
chris[ATTACH=CONFIG]n1090407[/ATTACH]Comment
HI Michael yes it is massive nr 8ft long an a beam of approx. 10" or so yes I started the scratch build a few days ago what with the nice wheather an as its big got to be built in the garge but im havin trouble sourcing material's has model shops keep closein down but I hope I can get everything to build the model for full r/c an im now goin to start to put the build pics on the forum in ships under construion an it will be a long build
chrisComment
If you’re building 1/72 armour then at least you’ll be able to find room for quite a lot of models — roughly four times as many as those of us who mainly build in 1/35 scaleComment
