Spots on the Internet 2020
    The Sea Gladiator was a Gladiator with arrestor hook & dinghy stowage................ as to other variants, the Gladiator was used by a surprisingly large number of countries - including Finland & Sweden - which used ski versions, but I've no idea which way ICM are going with this
      Hi found these don't think Dave has put these up before but if he has sorry.
      [ATTACH=CONFIG]n[/ATTACH]
      Pere.
        Havenโ€™t these Conquerors been around for a while already? I remember deciding to not buy the Mk. II because it would only end up unbuilt in the stash for the foreseeable future. Ah, yes, both from 2018, and the Badger is from 2019. So not new releases โ€” sorry
          From Facebook/website/emailshot of MiniArt - coming soon
Name:	miniart civvies.jpg
          A new departure for MiniArt - I wonder if they're making their own heads, or is it a collaboration?
          On the ICM Facebook page - model in process - 100% new moulds - Cessna O-2 in 1/48 sprues & CAD renders
Name:	icm 02 04.jpg
ID:	1123836Click image for larger version
Name:	icm 02 01.jpg
ID:	1123834Click image for larger version
Name:	icm 02 03.jpg
          Looks good!
          • rtfoe
            • 9113
            #275
            [ATTACH=CONFIG]n1123833[/ATTACH]
            [ATTACH=CONFIG]n1123836[/ATTACH][ATTACH=CONFIG]n1123834[/ATTACH][ATTACH=CONFIG]n1123835[/ATTACH]
            Looks good!
            The O2 looks much better than the Italeri ex Testors kit I built. It's even got the M-16's
            • Lee W
              • Feb 2014
              • 4655
              • Lee
              • Sherborne
              #276
              Excuse me, excuse me... sorry I didn't see you toes...!
              Guys, I did get a tad excited when I saw this but having read it, I'm not sure... anyone bud the Hapdong kit?
              Lee
                On the MiniArt Facebook page - coming soon, another T-54 Iteration
Name:	miniart t-54 dozer.jpg
                On the Rye Field Model Facebook page - 'next'
Name:	rfm pz iv.jpg
                  Hi found this.
                  New 35th scale T-34E First "Type Spaced Armour" / T-34-76 112 factory kit on the way from Border Model
                  [ATTACH]389969[/ATTACH]
                  Border Model have two new kits to show you - well, two in one really - with their new tooled "2 in 1" kit of the T-34E First Type Spaced Armour / T-34-76 #112 factory kit. We have some history of the two types to tell you which is which, some CAD images and a little video from Border model in our preview for you...
                  [ATTACH]389970[/ATTACH]New 35th scale two in one kit:
                  T-34E First Type Spaced Armour / T-34-76 #112 factory kit on the way from Border Model
                  "2 in 1 kit"
                  From Border Model1/35th scale Kit No #BT-009Plastic injection moulded kit with Photo-etch additionsProduct Link on the Border Model Website
                  [ATTACH]389971[/ATTACH]Border Model are pushing forward with a smart release program, this time with a new "Two in one" boxing of a couple of tanks from WWII Soviet Russia - the mighty T34 in two variant - the T-34E First Type Spaced Armour and the T-34-76 #112 factory versions. ALthough they are both based on the T-34/76 there is a fair difference between them. We will show you a little about both of them before we look at the kit's features we know of so far.
                  First a brief history of both types now...
                  T-34E "First Type Spaced Armour" E for ั ัะบั€ะฐะฝะฐะผะธ, "s ekranami" or "with screens"
                  By the beginning of 1943, the modernization of the T-34/76 was overdue. One of the attempts was the creation of a shielded tank. The Krasnoye Sormovo plant produced 68 T-34 tanks, the hull and tower of which were equipped with bulwarks.
                  The T-34E was fitted with additional side armour (no additional frontal armour on this variant)[ATTACH]389972[/ATTACH]It was assumed that they would protect the tanks from German cumulative shells. However, it was not possible to verify this - in the first battle, almost all combat vehicles shielded in this way were hit by conventional armor-piercing shells of the enemyโ€™s 75 mm anti-tank guns. After that, the screen venture was abandoned.
                  Summer of 1943. Variant of screening of Plant No. 112 "Red Sormovo" (Gorky).[ATTACH]389973[/ATTACH]The additional armor to the turret was a 16mm armor plate, which was bolted to the side of the turret at an angle of 5 degrees and at an angle of 35 degrees from the vertical, and at a distance of 70-150mm from the turret.
                  [ATTACH]389974[/ATTACH]The CAD drawing of the Shielded tank from Border Model[ATTACH]389975[/ATTACH]
                  T-34-76 #112 factory "Krasnoe Sormovo"By the end of WWII, more than 57,000 T-34 tanks had been built by the Soviet Union, of which 34,870 were the original version mounting a 76mm gun. Initially, the leading T-34 producer was factory No. 183 in Kharkov. This production facility was then followed by Factory No. 112, also known as Krasnoye Sormovo, situated in the city of Gorky. Named after Andrei Zhdanov, the factory was originally a Rail locomotive building facility. [ATTACH]389976[/ATTACH]The T-34/76 tanks produced at this factory had a number of distinguishing features such as notched glacis-hull side joints and a round access hatch on the rear plate. They modified the design of the Model 1941 tank to make it easier to produce, โ€œnotchingโ€ the front of the hull and glacis plate to fit together and adding handrails for infantry to clamber and ride with the tanks. [ATTACH]389977[/ATTACH]161 were built in the factory in 1941 and by the time that โ€œKrasnoye Sormovoโ€ changed over to the product-improved Model 1942 in 1943 โ€“ they had built more than 3,000 of this type.[ATTACH]389978[/ATTACH]CAD drwawing for the Border Model kit[ATTACH]389979[/ATTACH]
                  This kit from Border Model includes features for both kits such as:Full turret interior
                  [ATTACH]389980[/ATTACH]Metal gun barrel
                  Photo Etch parts includedWorkable track links & Suspension
                  [ATTACH]389981[/ATTACH]Border Model have made a short video about this kit we though you might like to see also...That is all the info we have on this two-in-one kit so far - more to you all as it surfaces - until then try reading the info from the link to the Border Model Website[ATTACH]389982[/ATTACH]
                  Pete.
                  • SimonT
                    • 2824
                    #279
                    [ATTACH]389983[/ATTACH]
                    8.8cm Pzgr.39/43 (APCBC-HE) L71
                    Reference: PMODEL002
                    Plastic model kit by PIG MODELS. Preorder product.
                    Estimated availability middle / end of June 2020
                    A model of a German 8.8 cm tank grenade Pzgr.39/43 L / 71 in original size.
                    Consist in easy to assemble 4 pieces (warhead, shell, base plate, fuse) of black PP and ABS plastic.
                    The kit includes stencils to paint the markings.
                    A new 1:1 shell from PIG Model
                      On the Zvezda Facebook page - on sale soon.............
Name:	zvezda t-28 1-100 01.jpg
ID:	1124115Click image for larger version
Name:	zvezda t-28 1-100 02.jpg
                      Zvezda now produce the T-28 in 1/35, 1/72, and now 1/100 - maximising their research! one for Gern!
                      On the ICM Facebook page & website, boxart for their 'May' releases
Name:	icm anzac model T.jpg
ID:	1124117Click image for larger version
Name:	ICM luftwaffe figs.jpg
                        New from Trumpeter in May
                        P-40E War Hawk 02269
                        Model: #02269
                        1:32nd scale
                          Soviet Object 292 Experienced-Tank
                          Model no #09583
                          1:35th scale
                            PLA Navy Type 054A Frigate 06727
                            Model no: #06727
                            1:700th scale
                              Flakpanther w/8.8cm Flak 41
                              Model no: #09530
                              1:35th scale
                              Total of 20 sprues, lower hull and upper hull
                              The kit consists of over 1200 parts
                                From the Kinetic Model Facebook page - available JuneClick image for larger version
Name:	kinetic tf-104.jpg
