Latest Acquisitions (2020)
Thanks to a local "give away my stuff instead of taking it to the dump" face book group a new seat for the cave.
Needs recovered and maybe some new webbing and the wood varnished/painted, but it will be a welcome upgrade to my dining chair.
(Fairly certain it was made by Ducal furniture so wasn't cheap.)Comment
These brushes arrived today. i cam across The brush maker Rosmary & co a while ago and really ;ike them. High quality but less expecsive than brands like W&N.
on the left is a set of 7 which cost £35. A bit of a punt really, it is a set marketed as for botanical water colourists. my thinking is that there is a lot in common between paintings figures and plants; some large areas and lots of thin details.it will be interesting to see how the two filberts (The two on the left) will do for larger areas of colour.
the odd brush on the right just intrigued me, described as 'red sable extended point' it will be interesting to see how good it is for long runs of details, such as uniform piping.
[ATTACH=CONFIG]n1136846[/ATTACH]Comment
I’ve been using them for several years as well, settling on series 93 sables as the best combination of spring/snap and longevity. They are fine up to size two, but the larger brushes don’t hold their point so well.Comment
If I could get a size four with a sharp point I would probably use it for most of my 28mm gaming figure work. It would speed up the production line significantly because it would minimise paint drying on the brush.......Comment
Another box of plastic to keep me busy on those cold winter nights, and perhaps even cold winter days.
[ATTACH]403989[/ATTACH]
295 parts so should take a while.
Andy.Attached FilesComment
the extended point brush is a size 4 - I'll let you know how it holds it point. It looks a nice combination of a sizeable reservoir and good point.
PeterComment
