Latest Acquisitions (2024)
  • Andy T
    • Apr 2021
    • 3239
    #1021
    I have a devil of a time with tweezers so thought I'd treat myself to a decent set, to see if it helped. So far, so good. They come together at the very tip first so even with my tendancy to grip on for dear life (I know I shouldn't) they don't seem to splay out and send parts into orbit
      Jim R commented
      Editing a comment
      I bought some decent tweezers a few years ago. They seemed silly expensive at the time but have saved me a lot of crawling about looking for pinged parts. i am sure you'll feel the same.
  • H2O Paul
    • Jan 2024
    • 14
    #1022
    A mate suggested I try a couple of 1/56 Rubicon kits and bought this last week. It came with so many options that you could nearly build 2 kits from the one box!
    You may only view thumbnails in this gallery. This gallery has 1 photos.
    • Jack L
      • Jul 2018
      • 1275
      • Cheltenham
      #1023
      Click image for larger version  Name:	IMG_9818.jpg Views:	0 Size:	436.0 KB ID:	1240130 Forgot to post these up. Excellent service from the shop as usual. The plants are excellent! Although I re-painted them, they would easily stand alone. Plenty in each box. Can be seen here: https://www.scalemodelling.co.uk/for...jack-s-bag-end
      • scottie3158
        scottie3158 commented
        Editing a comment
        They look good mate are they complete or do you build them up?
      • Jack L
        Jack L commented
        Editing a comment
        A bit of both scottie, the nettles and thistles are PE and single pieces than bent from a flat piece, the roses and mullein (no idea what they actually are) are paper and a little fiddly as the leaves, stalks and flowers are all separate. but they turn out very nicely
    • pjgtech
      • Dec 2023
      • 917
      • Peter
      • Swale Kent UK
      #1024
      Went into the local model shop to get a couple of jars of paint, and came out with a new model!
      I'm sure they do some sort of Jedi mind trick on you...(Spoken in Alec Guinness's voice) - " These are the models you are looking for".
      ๐Ÿ™‚๐Ÿ˜†๐Ÿ™‚
      Anyway I now have this for the shelf....
      A 1:16th scale figurine.
Name:	Brit Air Red Devils Orig Kit nov24 (1).jpg
      They had a couple of other figures, a US infantry man, and another, can't quite remember which? but I had an Uncle who did some parachute jumps in WW2, not sure where or if he was an actual paratrooper, but this particular model just spoke to me, so I had to get it.
      Having done a few very small 1:72 tanks I'm now getting used to the tiny parts and fiddly painting, so I'm looking forward to building this one at some point. Bit scary though as I've never done a figure before, and getting the face "right" seems a bit of a challenge, but hey, we'll give it a go.
      ๐Ÿ‘
      • Jack L
        • Jul 2018
        • 1275
        • Cheltenham
        #1025
        A special one that definitely deserves a mention. Huge thanks to scottie3158 who has sent these to me free of charge and wouldn't even let me pay for postage. Funds are tight at the moment so this amazing gesture will allow me to try my hand at something completely new. And Verlinden work doesn't come cheap at the best of times. Thank you Paul! Your kind gesture means more than you know.
        Click image for larger version  Name:	IMG_0034.jpg Views:	2 Size:	459.7 KB ID:	1240312
        • scottie3158
          Editing a comment
          Your more than welcome. Your kind donation to RBL is more than enough
        • adt70hk
          adt70hk commented
          Editing a comment
          scottie3158 - Very well done that man!
      • OldWalrus
        • Sep 2023
        • 42
        • Nick
        • West Sussex
        #1026
        A bargain from World of Books, should complement what I hope will be arriving in January!
        • Steven000
          • Aug 2018
          • 2830
          • Steven
          • Belgium
          #1027
          Some small bits...
          I'm always using Micro-Sol, so will try out Mr Mark Softer as I think it's a bit stronger?
          Also got some Abt.502 oil paints, but the middle one is actually an acrylic(!) didn't know they had an acrylic range so will have to look better next time. Cheers
          • adt70hk
            • Sep 2019
            • 10435
            #1028
            So some more essentials.....
            Having bent my 0.2mm needle slightly, I needed a new one and so I thought I might as well get two given how fragile they are....saves on a second lot of P&P when the inevitable happens!
            The white thing in the bag is actually a resin replacement to correct an error in the Airfix Sea Fury kit I recently acquired, which apparently leads to a misshapen nose if you're not careful, not to mention some incorrect detail.
            It's not something I would normally worry about but I was aware of the issue after a couple of people at shows put me onto the issue, one of whom used this very part. As I got the kit so cheap I thought why not get the AM correction! In case you're interested the part is made by Aerocraft Models, Product Code ACM48003.
            ATB
            The AM part in situ, with a wash to highlight the detail....
              • 18940
              First things Iโ€™ve bought for agesโ€ฆ.
              Click image for larger version  Name:	IMG_2523.jpg Views:	0 Size:	198.3 KB ID:	1240561
              New brushesโ€ฆโ€ฆthese are the best there are for painting figures, at least, in my opinion. Hereโ€™s whyโ€ฆ
              Click image for larger version  Name:	IMG_2524.jpg Views:	0 Size:	332.2 KB ID:	1240562
              Look at those tipsโ€ฆ..needle sharp. They have great spring and snap as well. As to longevity, here are these two alongside an old one (at the bottom) of three and a half years old.
              Click image for larger version  Name:	IMG_2525.jpg Views:	0 Size:	222.4 KB ID:	1240563
              The sharp point has worn off, but the old brush is still more than useable for anything but the finest work. This brush has done at least a thousand painting sessions. It is over three and a half years old.
              They are different sizes just in case you are wonderingโ€ฆ... Top is a size two, middle is a size O, and the old one is a size 1. I would have bought two new size 1 brushes, because they are the best compromise for my figure work, but they seem to be out of stock everywhereโ€ฆ.
              • Andy T
                Andy T commented
                Editing a comment
                Brilliant brushes. I have a 1 and 2/0. Far better than my painting level deserves ๐Ÿ˜‚
              • 18940
              Almost nothing you canโ€™t do with a size 1 from these guys is there Andyโ€ฆ..I use good size 1s for eyeballs on the little blokesโ€ฆfunnily enough, got a size OO and donโ€™t get on with it. Doesnโ€™t hold enough paintโ€ฆ.
              • pjgtech
                • Dec 2023
                • 917
                • Peter
                • Swale Kent UK
                #1031
                Latest wallet reduction device to appear at my door....
                Seem lots of peeps use these, so thought I'd get one.
                Tamiya paint stand with clips, etc.
                I know its mainly designed for air brushing, which I am not yet doing, but will be useful for brush painting also.
Name:	Tamiya paint stand 18nov24.jpg
                • pjgtech
                  • Dec 2023
                  • 917
                  • Peter
                  • Swale Kent UK
                  #1032
                  Little delivery just turned up, my first batch of oil paints courtesy of SMS.
                  Also brought a nice "dry" brush from my own local model shop.
                  • pjgtech
                    • Dec 2023
                    • 917
                    • Peter
                    • Swale Kent UK
                    #1033
                    Some more ancillary bits and bobs from our very own SMS, thanx...
                    Some Tamiya masking sheets with grids.
                    More pipettes
                    Some small flexi files.
                    Up to now I have been using the small individual paint palette tins, so thought I'd get a larger one for mixing etc.
                    Click image for larger version  Name:	new model bits 21nov24.jpg Views:	0 Size:	427.8 KB ID:	1241185
                    • pjgtech
                      • Dec 2023
                      • 917
                      • Peter
                      • Swale Kent UK
                      #1034
                      Just delivered by Mr Postman from those good folks at Hornby/Airfix direct from the Black Friday sale....
                      I think this is the reconnaissance version with ports for cameras, etc.
Name:	Mosquito airfix 1_72 plane 21nov24.jpg
                      • Geoffers
                        Geoffers commented
                        Editing a comment
                        Iโ€™ve built the originally tooled bomber version.
                        Itโ€™s a lovely kit, Iโ€™m sure you will enjoy it ๐Ÿ‘
                        Geoff.
                    • Geoffers
                      • Jan 2017
                      • 1742
                      • Geoff
                      This arrived yesterday
                      I do like a Coastal Command scheme ๐Ÿ˜Š.
                      I saw one of these for sale at Telford last weekend which I thought about getting then completely forgot about it until I had gotten home ๐Ÿ˜‚
                      Fortunately I saw one on eBay though which turned out cheaper than the one I had originally seen ๐Ÿ˜Š
                      Geoff.
