Latest Acquisitions (2024)
Arrived this morning at the Towers, if its good enough for Nightshift then its fine by me. Handle bending thing ! Had a bender before but every time it was the wrong width, at least this should cope.
[ATTACH=CONFIG]n1217725[/ATTACH][ATTACH=CONFIG]n1217726[/ATTACH][ATTACH=CONFIG]n1217727[/ATTACH]Comment
Bending grab handles Doug.
Yes can see that Rick, got to find the wire size now ?Comment
It’s a tool to bend brass (or similar) wire into handles for hatches etc. You undo the wingnuts, put a piece of wire between the two pieces of perspex, aligned with the notches that are the right distance apart for your handle, tighten the nuts and bend the wire to 90° on both sides.
I used to have one in steel from RP Toolz but I sold it last year because I found it awkward to use. Having to undo and tighten it every time, the sizes being in 1 mm steps when I often found I needed something like 3.5 mm, etc. all meant I never really used it.Comment
Any size works, but for grab handles I'm guessing between .030 and .040" in 1-35 scale. I use .012 to .015" for a 1" dia. grab in 1-87 scale. As Jakko mentioned, this is not one for the "mechanically impaired" individual. I have a system that works for me and I can knock out a good number of grabs in a relatively short time with excellent accuracy. :thumb2:Comment
