Welcom to the Forum Andy :upside:
Another waif & stray from MilMod.... eleven years and now looking for a new home.
Tim didn't warn you that the images here are kind of large. Any portraits will need appointments to the make up department first.:tears-of-joy: Not enough weathering to the cheeks.
RichardComment
First off, Welcome to the forum.
Albums: Well you can, but not really needed, Unless you want one that is.
Write the post and there is a 'button' Add Image. Click that and you can chose directly from your own drive and upload them from there.
Once they are uploaded they appear as a list under the text box. Then you can one of two things. Either click the button under the very top thumbnail; 'Insert All' You can choose to inset thumbnails or the full image. OR click the inset button by each image. Doing that you can write a bit of text, then add a photo, write a bit more, add a photo and so on.
It is a good idea to post the full image so all can see the content.
Hope that helps.Comment
Hi Andy - very good to see you. Is that how you get to work each day?
It appears that albums are not really used here. To be honest, they weren't often visited on Mil Mod and we only used them in order to install pictures in our threads. Here the process is much easier, as the site links directly to your computer's picture files. As Richard said, you get the choice of thumbnail or full image, which is a bit large and can give some gruesome results. An alternative is to use the file attachment function which creates a slideshow. Altogether I think I prefer this system.
Peter.Comment
Andy
So glad you landed safely after some turbulent air that you had to go through. Looking forward to seeing some of your builds soon
SteveComment
Attached FilesPer Ardua
We'll ride the spiral to the end and may just go where no ones beenComment
Hi Andy, great to see you've made it here.:thumb2:
Hope the last few months were good to you and looking forward to see some of your builds.
FernandoComment
