Following my Grandads footsteps...
  • Peej
    • Aug 2014
    • 919
    #16
    Welcome to the mad house Adam. Enjoy your new found hobby ( soon to turn into an obsession). Ask questions, take your time but most of all have fun.
    • rtfoe
      • 9086
      #17
      Welcome on board Adam, good you're starting with a smaller kit. That Saturn V rocket is quite an easy build as most of the parts are large.The rocket booster sections are basically empty and made mostly by roĺling large sheets of plastic card into cylinders. The complex parts would be the rocket nozzles for each stage and the command module with the Eagle lunar module(a model in itself) tucked in its compartment. I think you have a transparent section to view it.
      I built this kit when I was twelve and if I can do it you can.
      • spanner570
        • 15403
        #18
        Welcome Adam.
        Join and and have fun!
        Ron
        • KarlW
          • Jul 2020
          • 1522
          #19
          Welcome to the boards, Ron has summed everything you need to know about the hobby in his signature.
          • JR
            • May 2015
            • 18273
            #20
            Welcome Adam, a great forum full of helpful members.
              Originally posted by ManEatingSnail
              Hi all!
              Welcome
              I'm not sure when he purchased it, but from what my family have said they can't remember a time it wasn't sitting in the corner of the room gathering dust.
              There’s a clue on the box
              [ATTACH]393619[/ATTACH]
              It’s not going to be more than about 26 years old, and because kits (and other things) for these kinds of anniversaries tend to only be made for a short time, my guess is he bought it around that time. Unless, of course, it sat on the shelves at his local model shop for years, but even then I would expect it to have been in his possession for about fifteen to twenty years.
              • Del640
                • May 2020
                • 1151
                #22
                Welcome!
                I've been here a couple of months and have learnt shedloads from everyone here...
                Have fun!
                Del
                  Thank you all for the welcome! You're all very kind and its good to know that I have made a good plan of action.
                  Now onto the bad news...
                  I don't know why I never have, but I hadn't ever actually opened and looked through the box properly. I opened it when we were first going through his stuff after his passing and it "looked" like it was all there. However on further inspection I'm missing all of the lunar module parts and other bits and pieces. Also the plastic sheets that wrap around to make up the actual rocket have been damaged. He was always a bugger for starting something and then tossing it to one side when something else was bought lol.
                  Either way it leaves me in the situation that I'm going to have to try and get hold of another one so I can at least complete the build when I am ready to start the challenge. Ideally I would love to get hold of one from the same run as I have had a quick scan on the internet and seen they did another run for the 50th Anniversary back last year.
                    That's bad news, Alan - the Saturn V models weren't cheap models to start off with, and the years have made them somewhat collectible. This sadly means that the costs have gone up - the 50th Anniversary model sells for anything £55-85, and I haven't seen a 25th Anniversary model for sale. Ebay & KingKit are going to be your best bet - that & patience!
                      That was carried internally in the top stage, so if you want to pose it as it would be before/during launch, you wouldn’t need them (or so I assume — I’ve never seen this kit up close, let alone built it).
                      If it’s regular plastic card, then you could just measure its thickness (use calipers) and buy new card from a model (web)shop, then cut it to size.
                        I've seen a 50th anniversary one on ebay for £55 and they are selling them on Amazon for about £60, at least I know I can still get hold of one. Might do it sooner rather than later. Just in case!
                        • boatman
                          • Nov 2018
                          • 14479
                          • christopher
                          • NORFOLK UK
                          #27
                          HI Adam do it now as if you leave it will be gone
                          chris
                          • KarlW
                            • Jul 2020
                            • 1522
                            #28
                            Or wait 24 years until the 75th anniversary one is released.........
                            Though check out KingKit, but I have noticed when looking for some discontinued kits they're not always the best priced.
