Help please.
  • andrewmw
    • Feb 2022
    • 2
    Help please.
    Hi, I am new to this. I am retired and apart from a couple of very basic models in my youth, I have never modelled.
    I have bought a basic tool kit, mat and cement but am still to decide what type of models to concentrate on although aircraft or cars are my current favourites.
    Do I need to think about the scale at this stage? I assume that the beginners kits are generally a certain scale? What about after that?
    Should I buy some acrylic paints yet? I think I've read that beginners kits may come with paints or is this incorrect? If I need to buy some, is there a basic set of colours that I should get? Probably a difficult question to answer as I appreciate this may depend on model type, era etc.
    I think I read in another thread that a trip to Hobbycraft to look at kits (at least for a first purchase) would be helpful as they hold a decent range.
    Are there particular brands to go for or to avoid?
    Apologies for the number of questions. Any general help for a beginner would be gratefully received.
    Thanks.
  • JR
    • May 2015
    • 18273
    Firstly welcome to the forum Andrew.
    Depending on your sight with out buying an optovisor of which there are many to choose from https://duckduckgo.com/?q=optivisor+...ages&ia=images
    There are some who model in larger scale like 1/12 1/20 and mainly do busts and motor cycles,
    I do 1/35 but use an optovisor, 1/72 is also popular , but smaller and there more fiddley.
    Tamiya are good kits, they tend to go together well .
    As for paints, many use Tamiya, but suggest you would need some ventilation. I use acrylics, there are hundred's of colours to chose from .
    As to having a selection of colours, I would think it depends on what kit you are going to build, you can buy sets for aircraft and for a countries tanks.Those paints that come with those Airfix kits I think are enamel, so you would need thinners as well.
    Perhaps the best advice is to look at U TUBE, but don't be put off if it becomes all overwhelming about what you need , or should get.
    It takes time to build up tools and a paint rack.
    Any question you have on a kit will receive an answer on here, and remember no question is laughed at
      • 15735
      Hi Andrew
      Welcome to the forum. You will find a very friendly bunch of modellers here. John has given some sound advice already.
      My advice to you as a beginner is to buy a cheap kit, not an old rubbish kit as that will present many problems and might put you off altogether. Some of the Airfix 1/72 scale aeroplanes are great kits. Many come with glue, brushes and paint but the brush is usually poor and the cement is that gloopy stuff in a tube. I'd buy a couple of decent brushes and liquid cement.
      Be brave and share your build on here. I can guarantee that you will only get polite, helpful comments. We had a Group Build a while ago using just starter kits.
      Main thing is have fun.
      Have a look HERE, the Starter Kit group build. You can see what great results can be had with these straightforward, cheap kits.
      • Mark1
        • Apr 2021
        • 4156
        Welcome, perhaps some of the revell 1/72 planes would be a good starting point as they are pretty cheap and you can get some practise in.
        • langy71
          • 1950
          • Chris
          • Nottingham
          Can I just add to John's words... the only question that will be laughed at is the one you never dare to ask..
          • Bobby Conkers
            • Jan 2020
            • 529
            Welcome another Andrew!
            My advice, added to the above, is to dive in! Buy a kit you like the look of, and the paints for that kit, and try and put it together. You'll answer so many of your own questions as you'll see what you could have done, what tools would have made it easier, and ask for review from that.
            No matter what you do, your second model will be better than your first.
            Start a thread with your build and ask for help when you hit a snag. Every one of my build threads has been 10% progress and 90% discussion.
            This place is 100% friendly and non-judgemental, enjoy it!
              Andrew,
              welcome to the forum! My advice for choice of kit is - something that attracts you! If your fingers aren't as nimble as they used to be, then stay away from the smaller scale models. Some models can be very complex, and can kill your interest quickly, so try for a simpler model. I suggest you look around at the retail sites, Hannants, Model Hobbies, Jadlam, and of course the Scale Model Shop at what is available, select a few models, then ask here, on the forum, for opinions on the suitability as a beginners model. You'll get help from people who've maybe made the model & had problems ( or not ). Either way, before spending your cash, ask here - we're all happy to help!! :thumb2:
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                HI Andrew welcome
                chris
                • rtfoe
                  • 9099
                  Hi Andrew, welcome aboard. Every question is treated with dignity and replied with concern and practical tips of the ability of the modeler to be in mind. Be it starting off or at an advance stage. We still get asked if water can mix with oil and we have no problem answering time and time again. :smiling2:
                  We can be an absent minded old lot. :tears-of-joy:..trying to figure putting pieces together and having fun. Mind you there are experts here who are just as kind to share their experiences and mishaps at the bench. So dive in.
                  • Mini Me
                    • Jun 2018
                    • 10711
                    Hi Andrew, welcome aboard and glad to see so many folks eager to offer their suggestions.....I am afraid I can't add anymore to what's already been said but I am in total agreement with the comments and support you a getting from the members. Cheers and remember to have fun and enjoy your new hobby.
                    Rick H. :thumb2:
                    • Airborne01
                      • Mar 2021
                      • 4001
                      • Steve
                      • Essex
                      Welcome Andrew! If you send me your address I'll send you a buckshee 1/48 scale Airfix Sea Fury. There's a recent excellent build of this aircraft that will give some reference pointers!
                      • adt70hk
                        • Sep 2019
                        • 10422
                        Welcome Andrew.
                        I can only commend you for have THE truly outstanding first name!!!
                        lots of good advice above. Above all remember this is meant to be a fun hobby!!
                        All the best.
                          Kits aimed at complete beginners are mostly 1:72 scale aircraft packaged with small pots of paint, a brush and possibly glue , though you can also find other subjects like cars and ships, I seem to remember.
                          The scale doesn’t really matter all that much, though: larger scale generally means more parts, but the smallest of them will be about the same size as in smaller-scale kits. This is simply because manufacturers can really practically only mould things to a certain minimum size and modellers struggle with parts that are too small.
                          My advice would be to simply look for a subject that appeals to you, and when you find a kit you like, ask on the forum here if anyone has experience with it or thoughts about its difficulty. This because some kits are just harder to build than others, and if you happen to pick a kit that is notoriously difficult to put together, it’s just going to put you off I would say: buy a Tamiya kit as your first. They may be relatively expensive compared to many other brands, but both fit of parts and the instructions will be very good.
                          Basically the same as above Choose something that appeals to you, and you’ll soon get a bit of experience that will let you tackle more complex models or less-well-fitting kits.
                          I think I would buy a kit first, so you can work out which colours you need from its instructions. Once you decide this modelling stuff is a fun hobby, add some basic colours that are likely to be useful (red, blue, yellow, black, white, silver etc.) and again, from there, experience will soon build to show you what colours you’re likely to need — or not
                          As I said above, Tamiya is the one I would recommend. Well-designed, very good fit, fairly well-detailed and instructions that are easy to follow.
                          • andrewmw
                            • Feb 2022
                            • 2
                            Thank you everyone for your replies. Very friendly bunch.
                            I'm diving in with a couple of Airfix 1/72 starter kits to see how I get on.
                            Thanks again.
                            Andrew.
                              • 15735
                              Hi Andrew
                              I am sure you'll enjoy the Airfix kits. As they're cheap you won't worry too much about "just getting stuck in". Do share your builds, the forum is all about sharing and support.
