Hi everyone :)
  • TwitchyBill
    • Jul 2022
    • 19
    Hi everyone :)
    Hello everyone!
    I am a new member to this forum so thought I should introduce myself :smiling3:
    Name is Billy, and I have been making models (on and off) since I was a kid (I am late 20's now), although my dad did most of the work back then! I almost exclusively build 1/72 aircraft, although have acquired a few 1/48 kits recently. I also have a collection of unbuilt 1/35 Tamiya tank kits which I feel I am not good enough to attempt yet! I am open to building kits from pretty much any brand, but my go-to's are Airfix, Revell, Tamiya, Eduard and Academy.
    I think it is fair to say my skill does not match my love for making models, but I am learning how to perfect every aspect of the build, from the actual construction to painting, and eventually weathering and detailing.
    I have a question off the bat - I have never had much success with airbrushes, but this is really down to the fact I have only used suction-feed types (which are a nightmare) and cheap paints. I am determined to get a half-decent gravity-fed one and learn to use it properly. Are there any entry level brushes you could recommend?
    Thanks! :smiling3:
    Billy
  • stillp
    • 8093
    • Pete
    • Rugby
    Hi Billy, welcome to the forum.
    If you ask 100 people for a recommendation for an airbrush, you'll probably get 110 different answers! Do you have a budget in mind? Do you already have a compressor?
    • TwitchyBill
      • Jul 2022
      • 19
      Hi Pete,
      Good point! To be honest anything under £130(ish) would be ideal, and have seen a few for sale online but not sure how good these are. I have an air compressor, but it's a small one and not sure how compatible it would be with an airbrush.
      Billy
      • adt70hk
        • Sep 2019
        • 10409
        Originally posted by TwitchyBill
        Hello everyone!
        Thanks! :smiling3:
        Billy
        Welcome aboard Billy.... And pleased to here your dedicated to the one true scale i.e.
        I've recently started getting serious at that scale aircraft too, although 1/72 armour is still a big thing for me.
        Would love to see your work.
        ATB.
        • Mark1
          • Apr 2021
          • 4156
          Hi welcome to the forum,bartsharp do some pretty good for the price ab's, to get you started,I'm using a small compressor, upgrade as your skills improve.
          • TwitchyBill
            • Jul 2022
            • 19
            ATB.
            Thanks Andrew!
            Haha, you can't really beat a 1/72!
            Yeah I will submit my models as I do them - it will be nice to show them to fellow model-fanatics (my girlfriend isn't as interested in them :tears-of-joy
            I am not sure I have built any 1/72 armour kits, although I have done the Airfix 1/76 Tiger, Tiger 2 and Sherman kits.
            Billy
            • TwitchyBill
              • Jul 2022
              • 19
              Thank you, I will take a look. Yeah I have a small compressor too. I want to get an airbrush that is not too expensive or above my skill-set, yet good enough that it will last a while and still produces half-decent results!
              Billy
                • 15702
                Hi Billy
                A warm welcome to a great forum. Lots of airbrush recommendations. Best for general use in modelling is dual action, gravity fed with 0.3mm nozzle. That will cover 95% of your needs. If I had to go with one make it would be Iwata.
                The compressor would need to be capable of delivering up to 20psi but have the ability to dial it down. A compressor with an air tank will usually give a constant air flow, no pulsing.
                  Billy,
                  welcome to the forum. Don't worry about your skill not matching your love for making models! Nobody was an expert modeller from the off! As long as you enjoy your builds, and can see where you can improve, then that's progress. There's a wide range of experience in the membership, so don't hang back with your questions!
                  As Peter said 110 different answers for a choosing an airbrush!!! About the only thing I can chip in with is get a air compressor with a tank - without a good air supply, the most expensive airbrush is just an ornament!
                    • 18907
                    Hi Billy. Good of you to join us. There is only one rule…..have fun!
                    • TwitchyBill
                      • Jul 2022
                      • 19
                      Thanks Dave!
                      It's such a labour of love this hobby, I am always overly critical of my own builds but determined to get better each time! I see pictures and videos online of the 'experts' and would love to do what they can do!
                      Thanks for the advice, from what I am gathering by the replies so far the air compressor is the key, rather than the brush! So I have learnt that already ☺️
                      Billy
                      • TwitchyBill
                        • Jul 2022
                        • 19
                        Originally posted by Jim R
                        Hi Billy
                        Thanks Jim,
                        I do have a small compressor that runs at about 15psi, but doesn't have a tank. I have noticed the airflow can be a bit blotchy, and now I know why! Cheers!
                        Billy
                          • 18907
                          Billy
                          Not really Billy. What Dave is saying is that one is no good without the other. The best airbrush in the world won’t give great results with a poor air supply, and the best air supply in the world can’t make a bad airbrush perform better than it can. There is quite a lot in here about airbrushes so have a good read around and ask questions. Just expect everyone to give a different answer if you ask what is best. It’s one of those skills that we all seem to crack in a different way. What that tells me is that it’s actually hard to get it too far wrong, and whatever you buy will probably work pretty well :tongue-out3:
                          • TwitchyBill
                            • Jul 2022
                            • 19
                            Thanks Tim, I get what you are saying. I just suppose I didn't appreciate how important the air compressor was, I thought the brush was the be all and end all! I just need to get my confidence up on them again. It sounds silly but I even find mixing the paints a bit hit and miss, it's either too runny or so thick it won't come out of the nozzle! But yeah I just need to jump back on that horse, not be afraid to make mistakes, and keep trying and trying until I finally get the hang of it (hopefully!!! )
                            • stillp
                              • 8093
                              • Pete
                              • Rugby
                              See, you've had two different airbrush recommendations already! Personally I have a Harder & Steenbeck Infinity, but I know there are people who get good results from the cheap Chinese ones.
                              Whatever you decide it's worth buying form the Scale Model Shop, owners of this forum. https://www.scalemodelshop.co.uk/air...MaAlkjEALw_wcB
