Best paint
  • Russ1074
    • Feb 2023
    • 1
    Best paint
    Hi all.
    I’m Russ, new member, fairly new modeller, I’m currently using Tamiya paints, but find them grainy, and suggestions of something better ?
    Cheers in advance
  • BarryW
    • Jul 2011
    • 6012
    Welcome to the forum.
    Do you use an airbrush? If so then there is a different answer to a brush.
    Also, if you do airbrush, do you have an extracting air spray booth? Again that might be important.
      • 18269
      Welcome to the forum Russ.
      I suggest that you have a look in the forum section "the paint booth" there are a couple of dozen posts in there singing the praises of just about all the paints you can find.
      Asking what is the best is very much 'how long is a length od string'.
        • 15698
        Welcome Russ to a great forum.
        To help with your query, as Barry posted, we need to know how you're painting.
        • JR
          • May 2015
          • 18273
          Welcome Russ.
          • stillp
            • 8093
            • Pete
            • Rugby
            Welcome Russ. Tamiya pints, at least those I've used, have their (minor) faults but I've not seen them described as grainy before.
            • Del640
              • May 2020
              • 1151
              Welcome!
              Del.
                My experience is that if a bottle of Tamiya paint gets old (as in several years), it sometimes gets grainy, and if so, brush-painting with it gets very difficult because your brush will keep lifting up semi-dried paint you just put down.
                However, it needs to have sat in a bottle that has been opened before for quite some time for this to happen. I’ve certainly never seen it with a newly opened one.
                • Flip
                  • Jul 2022
                  • 257
                  • John
                  • Speyside
                  Russ,
                  Acrylic or lacquer?
                  I have just migrated over to their lacquer paints. They are brilliant. Then again, I airbrush.
                  Kind regards,
                  • Bri62
                    • Jan 2023
                    • 1882
                    • Brian
                    • Widnes Cheshire
                    Welcome m8 enjoy your stay
                    Brian
                    • Mickc1440
                      • 4779
                      Welcome to the forum neighbour :smiling:
