Woodwork
  • stillp
    • 8091
    • Pete
    • Rugby
    Woodwork
    I do a bit of woodwork occasionally. A few years ago I saw a very nice chest in an antique shop in Providence, R.I., described as a "Pennsylvania spice box". I couldn't afford it, but later when I came home found some plans so built something similar out of a mahogany bar top I was given by a colleague.
ID:	1096837Click image for larger version
ID:	1096838Click image for larger version
ID:	1096839Click image for larger version
ID:	1096840Click image for larger version
ID:	1096841Click image for larger version
ID:	1096842Click image for larger version
    Beautiful work Peter :smiling3:.
      That is lovely!
      Continuous grain running through the drawer fronts and proper joinery (including half blind dovetails if I've got the name right) are particularly special.
      • wotan
        • May 2018
        • 1150
        That's very impressive Peter. I am an admirer of great cabinet making.
          • 15677
          Hi Peter
          Craftsmanship at it's best. Looks beautiful.
          • minitnkr
            Charter Rabble member
            • 7528
            • Dayton, OH USA
            Excellent. Helped my Dad build a portable, folding wallpaper table out of the material many years ago. It held all the necessary tools within. Beautiful, but heavy. He said it would likely outlast both of us. PaulE
            • scottie3158
              • 14201
              • Holbeach
              Peter,
              That is a lovely piece of work. I used to enjoy watching the New Yankee workshop and the things he built.
              • Si Benson
                • 3572
                Very nice Pete,
                Do you use traditional tools or power tools and jigs etc? I only ask as Im looking into branching out into it myself.
                • Si Benson
                  • 3572
                  Peter,
                  Also loved watching Norm create some excellent pieces in his fully loaded wood shop! That and ‘this old house’ where my two fave shows...:smiling4:
                    I'm very envious of your skills Peter - a lovely thing. Unfortunately I can't even saw a straight line through a matchstick.
                    • stillp
                      • 8091
                      • Pete
                      • Rugby
                      Thanks for all the kind comments chaps.
                      Andy, I'm pleased you noticed the continuous grain - it was a struggle to lay out the cutting plan on the timber, as there were a lot of small holes in the bar top that I had to cut around, which is why the flame figure on the door isn't central.
                      Originally posted by Si Benson
                      Very nice Pete,
                      Si, I use a mixture of hand and power tools. The sides and top of this piece were too wide to go through my planer/thicknesser, so they were planed by hand. The smaller parts were machine planed to nearly the finished thickness then hand planed to remove the ripples from the machine. The rounded edges on the panels between the drawers were roughed out with a router then finished by hand, and the moulding around the top was done with a router. All the joints (half-blind dovetails, well spotted Andy) were cut by hand.
                      Ah, but I can't paint figures Peter!
                        • 18266
                        That is a beauty.
                        • minitnkr
                          • 7528
                          • Dayton, OH USA
                          Peter, I have a small aluminum miter box that clamps into my bench vise & works well w/my hobby saws and helps w/straight & 45 degree cuts. PaulE
                          • JR
                            • May 2015
                            • 18273
                            Ah beautiful Peter. nice finish, what did you use. Even after years of working with wood the smell of the workshop was great.
                            • stillp
                              • 8091
                              • Pete
                              • Rugby
                              I use a traditional beechwood one Paul. I have a miniature aluminium one for modelling but haven't needed to use it yet.
                              Thanks JR. It's French Polish, done the proper way, with a cotton rubber. It's improved a bit since those photos, with repeated waxing.
