Thanks Pete, oh yes when it gets good layer of wax on it the patina begings to build.
I tried some years ago a spray French Po!ish, completely the wrong name of course as it's the name of the application method rather than the polish which is as you know made from Shellac .Anyway it was supposed to let you spray a good number of coats, coupled with cutting back in a fast manor. Wasn't cheap but easy to spray, but it ended up being used for sealing pre polished tables that had been sprayed with furniture polish that when stripped that would always have " fish eye " caused by the silicone . If you ever have to refinish a table that has been polished in that way a coat or two of Shellac will block any silicone left in the surface. Handy hint no 356:smiling2:
