BMW R80 restoration
    • 18908
    Coming along mate. Amazing the change bead blasting makes. Better than new :thumb2:
    • Ancientmariner
      • Feb 2018
      • 859
      #32
      Yeah it's come out really well. Need to strip and rebuild gear box but at least it's clean now.
      Just doing last 2 cylinder heads and rocker covers and the block and it's all done.
      That's using 2 different machines, but both with glass media.
      • Nicko
        • Apr 2019
        • 1410
        • Nick
        • East Anglia
        #33
        Excellent! They've really come up nicely...
        Nick
        • Ancientmariner
          • Feb 2018
          • 859
          #34
          Block....Click image for larger version
          • tigersteve
            • Jan 2018
            • 678
            #35
            Looking Really Nice !!
            • JR
              • May 2015
              • 18273
              #36
              Unbelievable finish, take my hat off to you, your very skilled indeed James.
              • Ancientmariner
                • Feb 2018
                • 859
                #37
                So got most bits for engine rebuild ready (excluding gearbox which needs to be done) apart from a new set of cam followers which are eye wateringly expensive.
                Think doing away with the air box type filter for direct inlets onto heads will look good.
ID:	1176288Click image for larger version
                • PaulinKendal
                  • Jul 2021
                  • 1608
                  • Kendal
                  #38
                  Um, are you dispensing with the carbs as well as the airbox? Could make for a very lean mix! :smiling5:
                  Seriously, this is amazing - I wish I could do this sort of thing.
                  • Ancientmariner
                    • Feb 2018
                    • 859
                    #39
                    Ha ha not quite, carbs are in a lot of bits currently
                    • Ancientmariner
                      • Feb 2018
                      • 859
                      #40
                      Finally rebuilding. Slow and steady but got a bit done today.....
                      • Code no 10
                        • Jun 2022
                        • 130
                        #41
                        Hi Ancientmariner,
                        Does your boxer engine makes a manly mumble sound?
                        I had a chance to visit a car show, and a Subie WRX sounded absolutely fantastic, well....at least to a nerd like me.
                        • tigersteve
                          • Jan 2018
                          • 678
                          #42
                          Great project to watch coming together!
                          • Ancientmariner
                            • Feb 2018
                            • 859
                            #43
                            Originally posted by Code no 10
                            Hi Ancientmariner,
                            It makes no noise at all currently and won't for some time as there are boxes of components everywhere.
                            For nosie I favour the German V8s
                            • Ancientmariner
                              • Feb 2018
                              • 859
                              #44
                              Slowly Steve, shame the assembly lube took so long to arrive.
                              • Ancientmariner
                                • Feb 2018
                                • 859
                                #45
                                So unfortunately I do not have an up to date photo but the rods are in, crowns on and barrels and heads on as well though not tightened. Honed the cylinders and fitted new piston rings. Hoping when I return to make some substantial progress and maybe get it running even if its just on the bench. As always spares for something this age are a pain, especially when stuff that should fit doesn't.
