Steven's Fw190 1/48 Eduard (AlanG GB)
  • Steven000
    • Aug 2018
    • 2826
    • Steven
    • Belgium
    (feel free to reuse header image)
    Hi guys,
    It’s an honor to participate in this GB for Alan. I've chosen this 1/48 Eduard Fw190A-8 (N° 82147)…
    Although the kit offers no less than 5 paint schemes, my eye fell on this scheme from the book “Planes & Pilots, Fw190 1939-1945, p54” (French version)...
    Which seems to be based on this Fw190F-8,
    AlanG used the Wilde Sau (wild boar) insignia of the Luftwaffe night fighters as an avatar for a long time,
    So in an attempt to make a creative reference to his avatar I would like to make a small diorama with some ground crew on top of the wing, under attack from a wild boar after they caught one of its piglets for dinner… We’ll see how that turns out, the plan is to create the animal in 3d and print it...
    Sprue shots...
    I can use the "9" for the scheme from the book,
    Thanks for reading,
    cheers
    • 15668
    Definitely a great idea. An interesting build/dio to see come together.
    • colin m
      • 8740
      • Colin
      • Stafford, UK
      That looks like a nice kit, then again, I do like Eduard. The scheme looks very different, I do like the dirty winter look of some aircraft.
      • Geoffers
        • Jan 2017
        • 1696
        • Geoff
        Great dio idea, looking forward to seeing it come to fruition ?
        Geoff.
        • yak face
          • Jun 2009
          • 13829
          • Tony
          Great idea steven , I love the idea of the crew hiding up on the wing with an angry Boar underneath!
            • 18891
            Should be good. Great dio idea as well…
            • scottie3158
              • 14201
              • Holbeach
              Sounds great I will follow along if I may.
              • HAWKERHUNTER
                • Feb 2012
                • 1562
                • Steve
                • Halifax, West Yorks.
                Great idea Steve. That camo will be a challenge. Best of luck.
                • Valeron
                  • Jan 2022
                  • 931
                  • Mike
                  • St Albans
                  Looking forward to this.
                  Live the diaroma idea.
                    • 22770
                    A cracking idea Steve, one I’m sure Alan would have liked very much.
                    • Steven000
                      • Aug 2018
                      • 2826
                      • Steven
                      • Belgium
                      Thanks guys,
                      Made a start on this, some parts for the cockpit...
                      I'm used to work on less advanced/cheap models, so I'm quite impressed with the kit, many options to build as you like.
                      For example the instrument panel can be made from :
                      - molded gauges (green)
                      - colored PE gauges (yellow)
                      - flat panels with decals (red)
                      I will try the colored PE parts for a change, as I always had molded gauges on my builds.
                      Still had a German resin pilot (PJ productions) in the stash for one of my Bf109's,
                      I think he will suit well for this project, looking at the crew standing on the wing.
                      Cleaned and glued him up with superglue, he sits a bit angled to make the arm work on the fuselage,
                      Even got some Vallejo-primer and base colors done with the airbrush.
                      Painted the spinner white so I can mask a spiral...
                      That's all, thanks for reading - cheers
                      • Geoffers
                        • Jan 2017
                        • 1696
                        • Geoff
                        Good start Steven, the figure looks very nice ?
                        p.s. thanks for allowing use of the header image. How do I use it? ?
                        Geoff.
                        • Steven000
                          Steven000 commented
                          Editing a comment
                          Thanks Geoff, if you like the header, you can right-click on it, save the image and then use it in your own topic as the first image. Cheers
                      • HAWKERHUNTER
                        • Feb 2012
                        • 1562
                        • Steve
                        Excellent progress Steve. It wil be interesting to see how your kit comes together as mine is an Eduard kit also
                          • 22770
                          Very nice work so far Steve.
                            • 15668
                            That's fine progress. Pilot looks good - hope he fits OK. I like Eduard's choice of instrument panel.
