Nice progress Tim, looking good ? cheers
Tim’s 1/48 Eduard FW 190 A-2
That's an eye-catching paint job Tim. Nicely done. I often wonder why gloss varnishes give trouble. Same varnish, same technique behaves perfectly and then for no apparent reason it is not gloss, patchy, orange peel, spots etc. I actually hate airbrushing a gloss coat for fear of it going wrong. It's usually towards the end of a build which makes the worry worse.👍 1Comment
👍 1Comment
Hi Tim,
I've only just read through the thread and it is interesting and good to know of a good 190 kit to get if I want one.
Even if everything is straight from the box it still needs skill to put together neatly and it shows here. You haven't lost any of that skill even with the panel lining...no one can get it straight at one pass so I cheat by going over mine several times with very translucent paint. Patient layering and stopping at just the right level will not obscure panel lining. It all depends on how much you want to reveal.
At 1/48 details on joysticks are hard to notice so I would have missed what you did anyway unless I do a CSI with a torch light. Nice rescue with the wire.
Not many will do specific priming colours but the results speak for themselves.
This is coming on fast. I try to stay away from GBs now as I always can't finish on time. Yes this GB has a sad reason but a good tribute.
Will you have a clean finish or weathered a little?
Wabble👍 1Comment
👍 1
Hi Tim,
Wabble
As to weathering, I will add cannon soot and exhaust stains, and possibly hinge streaks from the control surfaces and radiators, but not much else. I like aircraft fairly clean, and don’t think axis aircraft ( in particular) lasted long enough in service to get too beat up.👍 1Comment
👍 1Comment
Quick question Tim - when you did the decals were they the new Eduard ones that have the removeable carrier film ? I’m asking because Ive just tried to put the spinner spiral on mine and it seemed very strange . The carrier film was really shiny and not very flexible at all , I’m wondering if mine are the new ones and if so how did you cope with the spinner spiral on yours?Comment
Quick question Tim - when you did the decals were they the new Eduard ones that have the removeable carrier film ? I’m asking because Ive just tried to put the spinner spiral on mine and it seemed very strange . The carrier film was really shiny and not very flexible at all , I’m wondering if mine are the new ones and if so how did you cope with the spinner spiral on yours?👍 1Comment
