Fuselage now glued and drying . The undercarriage wells have been assembled and painted , the cannons that go through the wells have been left out though . I fitted a couple of small pieces of brass tube to the rear spar so I can fit the cannons after painting ( they would be bound to get knocked off ) which will be made from brass tube . The undercarriage legs are supposed to have the scissor links cut off and replaced with PE but as is often the case , the PE doesnt look right , being too thin and flat. Plus , the cutting off of the links would have been a messy job and probably weakened the leg too. I decided to leave them but drill the holes with 0.7 and 0.8 mm drill bits.
Tonys Eduard 1/72 Fw190A-8
Thatโs going great Tony. Itโs amazing how similar it looks to the 1/48 version. The level of detail is pretty much the same, so some of those parts must be pretty smallโฆ..๐ 1Comment
Thanks tim , yes the level of detail is excellent for 1/72 and the fit and precision of the parts rivals Tamiya standards . Iโm hoping to do the Airfix 190 after this and use one of the spare decal options so it will be interesting to see the comparison , cheers tonyComment
As this kit is so precise its vital to test fit before gluing , sometimes even a coat of paint on mating surfaces can make a difference . In this case a dry fit showed that the undercarriage bay insert needed a slight sanding to close up the joint on the cowling. Now the wing bottom is fitted next up is the tops , which from a test look like they will fit perfectly with no further attention needed .
Attached Files๐ 5Comment
Wing tops now on and as mentioned , apart from the seam on the wing leading edge no further attention required . The thought that has gone into the design of this kit is amazing . Eduard have made sure the majority of the joints fall on actual panel lines and the precision of the fit combines to make the build fuss free ( and therefore filler free! )๐ 8Comment
Got this ready for primer now . The rear canopy is one of the unused spares provided , just tacked on to mask the cockpit during painting. The front part of the cowling and nose ring have been left off too , reason being the cowling front is painted Rlm 02 and the nose ring Rlm 74. ( see camo option C , first post ) . Rather than have a tricky masking job Iโm going to paint them separately and fit them last off , they should just snap fit in .๐ 7Comment
๐ 7Comment
