As Tony (Yak Face) says this is a great kit. Fiddly but the fit is superb. It almost clicks together like Lego
I am now ready for primer. I have built a simple jig to hold it and used the spare rear canopy rather than fit and mask the one I'm going to use. The kit provides a clear part for open canopy and for closed. I'll use the closed to 'mask' the cockpit as I'll actually use the open version.
The drop tank fits perfectly but you need 3 hands to fit it!
The undercarriage is very fiddly to put together correctly. I didn't use a PE part but I did drill out the plastic part.
Excellent progress Jim , I did the same with the canopy . I also did the same with the scissor links , the PE replacement looked too thin and cutting off the moulded ones would have been a pain .cheers tony
I've got some paint on. All MRP.
Masked up (sorry about the strange colour - camera setting was wrong )
Masked remove and no touch ups needed
Still a way to go as there are the dreaded mottles and having seen how well others have done I'm rather nervous. Also there is a black front end with a zig-zag edge to it with a white line!!
