Joe's Tamiya 1/72 FW190D-9
    • 22770
    #16
    Looking great Joe, nice work so far.
    • flyjoe180
      flyjoe180 commented
      Editing a comment
      Thanks Ian
  • flyjoe180
    • Jan 2012
    • 12390
    • Joe
    • Earth
    #17
    Just to prove things are moving with this build, here we are after RLM76 applied, masked for the upper camouflage. Once painted I will apply mottling and the lower edges of the upper camouflage.
      • 22770
      #18
      Coming along very nicely Joe, looking forward to seeing this in all its war paint.
      • flyjoe180
        • Jan 2012
        • 12390
        • Joe
        • Earth
        #19
        A bit of paint tidying up to do, and on to the mottling next.
          papa 695
          commented
          Editing a comment
          Very nice work Joe.
      • Geoffers
        • Jan 2017
        • 1697
        • Geoff
        Looking good Joe ?
        How are you planning on doing the mottling?
        Geoff.
        • flyjoe180
          flyjoe180 commented
          Editing a comment
          Thanks Geoff. Slowly but surely... I'm going to dilute the paint a lot, lower my airbrush pressure, remove the needle cap, get in close and pray.
        • 15677
        Camo's coming on nicely. That black masking stuff is quite strange, you have to spray quite soon as it slowly flows downwards. At least the stuff I have does.
        • flyjoe180
          flyjoe180 commented
          Editing a comment
          Thanks Jim. Yes, it's the same masking putty stuff that is packaged by a few model supply manufacturers. Yes, it does flow with gravity. Come back the next morning and it will look like the Persistence of Memory painting by Salvador Dali. Great to watch in its tin though, self levels and is rather satisfying.
      • flyjoe180
        • Jan 2012
        • 12390
        • Joe
        • Earth
        #22
        My first Luftwaffe mottle complete. I practiced with various mixes and pressures and distances on a piece of primed plastic, and during the paint job, a piece of cardboard. I ended up with approximately 90% thinner to 10% paint, pressure set to 12 PSI, and the needed cap removed. I varied the distance to the model according to the pattern I wanted. A couple of cock ups, but thankfully nothing that couldn't be corrected. In many ways this is more forgiving to apply than the uniform and tight schemes found on RAF aeroplanes. I also took the opportunity to paint the trim tabs red (second photo). Gloss varnish next.
        • minitnkr
          minitnkr commented
          Editing a comment
          Camo came out great.
        • Nicko
          Nicko commented
          Editing a comment
          Looking very nice Joe...
          Nick
        • Steven000
          Steven000 commented
          Editing a comment
          Nice paintwork Joe ? cheers
      • Geoffers
        • Jan 2017
        • 1697
        • Geoff
        That’s a fine job you’ve done there Joe, it looks great ?
        I’ve got mine to do next, I’ll be chuffed if it turns out as well as yours.
        Geoff.
        • flyjoe180
          flyjoe180 commented
          Editing a comment
          Cheers Geoff!
        • 22770
        #24
        A very nice job on the mottle indeed Joe.
        • flyjoe180
          flyjoe180 commented
          Editing a comment
          Thanks Ian
      • yak face
        • Jun 2009
        • 13831
        • Tony
        #25
        Fantastic mottle joe , I suspect this wont be your last now youve mastered the technique ! Cheers tony
        • flyjoe180
          flyjoe180 commented
          Editing a comment
          Thanks! 'm already eyeing up my next mottle job Tony.
      • flyjoe180
        • Jan 2012
        • 12390
        • Joe
        • Earth
        #26
        Decals on, but not without issues. As I discovered early in the build, these are very thin and delicate decals, not the usual thick type that Tamiya often supply. They hate handling and decal solutions. I started with the JG301 ID band, knowing this would be the one that would break if any were going to. Soaked in warm water, prepped the area with water, no solution. It went on okay to begin with, but it was impossible to manoeuvre after a few seconds, and then proceeded to disintegrate. So did one of the swastikas. I used a spare for the swastika, masked off and sprayed the fuselage bands. The remainder of the decals were soaked in cold water, I was very careful not to apply them until they were totally free moving on the paper. Even so you only get 30 seconds or so to place them before they decide to make wherever they are their home. I also blindly followed the decal numbering and made an error with the wing walk way markings, but they are in their permanent homes and there they shall stay. I'll try to find something in my spare decal box. In the meantime, here we are, with a very sparing amount of decal solution overnight.
        • minitnkr
          minitnkr commented
          Editing a comment
          It looks good to me. Nice result.
      • HAWKERHUNTER
        • Feb 2012
        • 1566
        • Steve
        • Halifax, West Yorks.
        #27
        Great work Joe. You nailed the camo and top marks for battling on with the decals. Looks amazing mate.
        • flyjoe180
          flyjoe180 commented
          Editing a comment
          Very kind Steve, thanks
      • flyjoe180
        • Jan 2012
        • 12390
        • Joe
        • Earth
        #28
        Completed model is in Alan G's memorial gallery here https://www.scalemodelling.co.uk/for...d-9-for-alan-g
