Spanner's Airfix 1/72 Fw190 A-8. Eastern Front.
    • 15681
    You've done well with that yellow. I find it a horrible colour to paint whether with an airbrush or a brush.
    • Nicko
      • Apr 2019
      • 1402
      • Nick
      • East Anglia
      #17
      You are really flying along with this Ron. Just caught up on your last few days posts..
      Nick
      • spanner570
        • 15389
        #18
        Thanks Jim and Nick.
        I've dropped a bo****k!
        I've just noticed the yellow fuselage band is way too close to the rear of the aircraft by at least 4mm! It might not have been noticed on the finished model(or folks would be too kind to mention it) but I would know.
        So back to the bench with brush in hand I go.......
        Such is the lot of us model makers.
          • 15681
          So a Ron type c***-*p. You really must try harder.
          • spanner570
            • 15389
            #20
            Here you go, JIm.
            A bit of 'Lady Luck' works wonders! Ready for it's final coat and general tidying up of the colour edges.
            The original yellow was where that small indent is.
            Bit of a tip for anyone else daft enough to make a similar mistake. Don't paint over the original yellow. Concentrate your efforts on the new band of colour only. If you do paint the original at the start, the colour will go progressively darker and you will never match the two shades. Once happy with the match, only then finally paint the whole thing. The trailing edge white is straight forward. Just use enough coats of white to obliterate the yellow, blending in each one to the original.
            Click image for larger version  Name:	P1390181.jpg Views:	0 Size:	171.7 KB ID:	1247421
            Cheers.
            Ron
            • spanner570
              • 15389
              #21
              Finished.
              Squeeky clean, just as the ground crew steps away......
              I will add some weathering, a simple base etc. when I put some new images in Al's 'Completed'
              A bit of history.....
              The model is of No. 7 JG 54 during the winter on the Russian Front during WW2. Their aircraft were painted in various schemes. White paint was applied all over the upper surface over the factory colours or simply in white patches directly over the original colours. There was no 'Standard'. I've used an all over white, except where the upper main wing decals are. These would have been painted around when the white was applied. Painting the factory colours on the wing decals was a pain.....
              About JG 54's boss.
              Flying no. 10, Walter 'Nowi' Nowotny was the holder of the Knights Cross with oak leaves, swords and diamonds. He shot down 258 enemy aircraft over the course of 442 combats.
              He was killed flying a Me 262 during combat with American escort fighters on November 8th 1944.
              Meanwhile here is the finished FW 190.
              All brush painted.
              After the all over coat of white, I marked out the pattern with a pencil then painted in the patches using the small pots of paint and the brush usually associated with Airfix Starter Packs.
              As I didn't have the decals, I've used a bit of licence and used one's from my spares drawer. Not far off in the main.
              A bit dark and the white really is white. Sorry about that.
ID:	1247842 Click image for larger version
ID:	1247843 Click image for larger version
              Cheers all
              I hope you approve Al......
              Ron
                • 15681
                Great result Ron. Al would have certainly added another ?
                • Nicko
                  • Apr 2019
                  • 1402
                  • Nick
                  • East Anglia
                  #23
                  Really like that scheme Ron. Lovely job.
                  Nick
                  • scottie3158
                    • 14201
                    • Holbeach
                    #24
                    Ron, That's a cracking result mate.
                    • Tworrs
                      • Jan 2022
                      • 1980
                      • Garry
                      • New Zealand
                      #25
                      Excellent work and a fine result Ron
                      • flyjoe180
                        • Jan 2012
                        • 12390
                        • Joe
                        • Earth
                        #26
                        Lovely work Ron, and that scheme certainly is a point of difference
                        • Valeron
                          • Jan 2022
                          • 931
                          • Mike
                          • St Albans
                          #27
                          Very nice Ron. And good to see another different colour scheme.
                            • 15681
                            Just noticed that there is a heart on both sides just below the canopy. Are the hearts just accidental or are they a deliberate part of the camo?
                            • spanner570
                              • 15389
                              #29
                              First off, thanks to all you wonderful folks for such nice posts. It's made all the hair pulling, cursing and consequent contributions to our mantlepiece RNLI swearbox worth while!
                              Jim, they are or were, a deliberate part of the camo. of JG 54 and a right pig to pencil on and paint summat like too.....
                              Cheers and thanks again all.
                              Ron
                              • Gern
                                • 9213
                                #30
                                Beautiful
