I mentioned earlier that I had the Airfix fw190 starter set and that I might get it going alongside the Eduard build so here it is . Its one ive built before and is a really nicely done kit. The detail is excellent for this scale and it builds up without any problems . The only downside to this particular boxing ( starter set ) is the rather plain choice of scheme ,plus the decals are quite basic with no stencils of any type included . Luckily the Eduard came with 5 decal options so by combining the iron crosses from this with the spare unit markings from the Eduard I can do a slightly more interesting scheme.
Tonys Airfix fw 190 a8
Seems like quick progress but I actually started this a few days ago but only just got round to starting the thread. Cockpit is now done , very nicely done by Airfix - not a thousand separate pieces but enough to give a very good representation ,the instrument panel decal being very effective . Only thing extra thats needed is the addition of some Eduard pre painted PE belts .
Attached Files👍 9 -
Started to get the airframe together , starting with the wing top and bottom . The instructions say to fit the cannons and machine guns between the top and bottom but I just know they would get knocked off .So like the Eduard build the base of the cannons was cut off , fitted and drilled out so I can fit brass tube replacements last off . The machine guns were similarly cut off and drilled ready for brass tubing later.
👍 4Comment
Coming on a treat Tony. I have just got to the cannons on the Eduard kit and, like you, I'm certain to damage them if fitted early. Yours is such a sensible solution.👍 1Comment
cheers tonyComment
Wings now on and the two panels on the top of the fuselage are fitted . The Airfix kit features machine guns on the nose - the Eduard kit has these faired over and the decal option i’m intending to use for this from the Eduard kit also features faired over gun troughs . Do for the second build in a row cocktail sticks were employed !
I cut off the ends and sanded them to less than half their thickness, these were then superglued to the cowling . Once theyve had a coat of primer they should be fine .
Attached Files👍 4Comment
