Tonys Airfix fw 190 a8
    • 22770
    #16
    Looking good Tony.
    • yak face
      • Jun 2009
      • 13829
      • Tony
      #17
      Top colours now on and masking removed.
ID:	1249068 Click image for larger version
      Mottle has now been applied . According to the Eduard colour profile the machine I’m doing has a much smaller / lighter mottle pattern than the one I'm doing on the Eduard kit .
ID:	1249070 Click image for larger version
        • 22770
        #18
        Coming along very nicely Tony.
          • 15669
          Smart looking paint job. Still got my mottles to do
          • yak face
            • Jun 2009
            • 13829
            • Tony
            #20
            After giving the model a coat of johnsons Klear yesterday I got the decals on today . I used the Airfix sheet and spares box for the crosses and the spare Eduard decals for the unit markings and stencils . The decals were laid onto a wet patch of klear to aid adhesion and reduce the chance of silvering . Its now drying down so tomorrow I can give both the 190s a couple of coats of matt to seal everything in and give a nice finish , then its a case of fitting all the last bits .
              papa 695
              commented
              Editing a comment
              Very nice indeed Tony.
          • HAWKERHUNTER
            • Feb 2012
            • 1562
            • Steve
            • Halifax, West Yorks.
            #21
            Great job Tony
            • yak face
              • Jun 2009
              • 13829
              • Tony
              #22
              Light panel line wash applied and after clean up its now had a couple of coats of matt varnish . Ive also fitted the undercarriage . Next ,a little light exhaust and oil staining then more little bits to add ( guns , aerials ,canopy etc ) .
ID:	1249414 Click image for larger version
              • yak face
                • Jun 2009
                • 13829
                • Tony
                #23
                In parallel with the Eduard ,this has now had the guns and cannons fitted using brass tubing. Its also received the exhaust staining , in the case of German machines in WW2 a dark brown as their aviation fuel was derived from coal - allied aircraft often have a black / light grey staining due to the lead content and higher octane . Ive also added a litlle light chipping on the port wingroot as pictures of this aircraft show this .
ID:	1249481 Click image for larger version
ID:	1249480 Click image for larger version
ID:	1249482 Click image for larger version
                • yak face
                  • Jun 2009
                  • 13829
                  • Tony
                  #24
                  Nearing the end now , its just a case of all the final little details to add . Ive painted the guns and pitot and had a look at the DF loop and aerials . The Airfix kit doesnt supply any of these so time to scratch . The DF loop was made from fuse wire wrapped round a suitably sized rod and the Morane antenna ( the one that looks like a hockey stick under the wing ) was made from a wooden stirring stick with another bit of thinner fuse wire stuck on . The whip aerial behind the DF loop will be a toothbrush bristle . From pictures ive seen it looks as if the Morane antenna was made from wood so I dont even have to paint it ?.
                  I dont know if its because its for Alan or what but I’m really chuffed with how these two are turning out , I hope he would be too .
ID:	1249565 Click image for larger version
ID:	1249566 Click image for larger version
ID:	1249567 Click image for larger version
                  • yak face
                    • Jun 2009
                    • 13829
                    • Tony
                    #25
                    DF loop , whip aerial and Morane antenna now fitted . The Morane antenna has been left unpainted as these were just varnished wood on the actual aircraft . Next is fitting the canopy - the aerial wire on these early canopies was tensioned to stay taut even when the canopy was open , passing through on rollers but photos of this particular machine show the wire slack so it must have been disabled and fixed rigid . I also gave the fuel tank a black front and a lot of oil stains as seen in this pic of the aircraft ( note , personal wording not yet applied at this point ) Click image for larger version
ID:	1249896 Click image for larger version
ID:	1249897 Click image for larger version
                    • flyjoe180
                      • Jan 2012
                      • 12381
                      • Joe
                      • Earth
                      #26
                      Beauty Tony, looking forward to seeing the finished product
                      • yak face
                        • Jun 2009
                        • 13829
                        • Tony
                        #27
                        All done now , the canopy has been fitted and the aerial wire attached hanging down . Thanks to all who've been watching . I’ll put some more pics on a completed thread later , cheers tony
ID:	1249987 Click image for larger version
                        • Geoffers
                          • Jan 2017
                          • 1696
                          • Geoff
                          Nice one Tony, lovely job ?
                          Geoff.
                          • HAWKERHUNTER
                            • Feb 2012
                            • 1562
                            • Steve
                            #29
                            Great finish Tony well done.
