How does a build make it to the completed builds section?
  • Neil
    • Nov 2013
    • 365
    As the question says, do I move it (if so how?) or does it happen via moderator magic?
    You have to post it as a new thread in the completed build section
      Hi Neil.
      As Tibbs has mentioned, you must post a new thread on the completed build section.
      When you are posting the tittle, you will found some tools to mark it as a completed build if you want (better do it...)
      If you have some problem, need to move or edit it, let me know!!!
      I'm a newbie moderator!! But I will be more than glad to help you
      Polux
        • 18269
        Yes it's that simple.
        Make a thread in the completed section. Write as much as you like about the kit and what was used to paint and finish it then some good photos of the end result.
        • Neil
          • Nov 2013
          • 365
          Sheesh, I am a global moderator on another completely unrelated site and have got so used to being able to perform God-like functions to posts, having to do things the way the hoi polloi do things again is a right pain in the bum
            • 18269
            It was discused a while ago in the mods room but it stays as it is. So says the boss!
