Cheap and cheerful duo
    May I make a modest contribution to this Group Build? Only 1/72 and quite old kits I think, but they come with a pilot figure. I can try some rigging, too.
    If I get the taste for WWI planes, I can always get some more as they are less then ยฃ4 a go.
    Tony
    [ATTACH]43595.vB[/ATTACH]
    [ATTACH]46838.IPB[/ATTACH]
    Nice kits, looks like the bi-planes are taking over. Beautiful looking planes i think.
    Andy
    • yak face
      • Jun 2009
      • 13870
      • Tony
      Nice pair tony, although the pilot in the triplane is unusable , i know , i did this one a bit back. Apart from that its quite a good old kit, little bit of filler here and there but well worth a couple of quid! cheers tony
      • tr1ckey66
        • Mar 2009
        • 3592
        Hi Tony
        I think I'm going to enjoy watching these 2 get built. You've chosen great subjects I'm sure you'll enjoy the kits.
        All the best
        Paul
        • yambam26
          • Mar 2011
          • 622
          Ive got the Revell Sopwith Camel in my stash and its a decent little kit and for ยฃ2-ยฃ3 you can't go wrong!
          Ill be looking out for the progress updates
          Ben
            Thanks gents. I've made a start on them, I'll try to do them together. The triplane looks pretty poor; more flash than a 70s disco, and the mouldings are far from smooth. Maybe I got a bad one. It will test my skills with filler, anyway. The pilot has a little moustache - I reckon they modelled him on Terry Thomas.
            The Albatross seems much better on initial dry-fitting.
            This is the triplane:
            [ATTACH]44090.vB[/ATTACH][ATTACH]44091.vB[/ATTACH][ATTACH]44092.vB[/ATTACH]
            [ATTACH]47294.IPB[/ATTACH]
            [ATTACH]47295.IPB[/ATTACH]
            [ATTACH]47296.IPB[/ATTACH]
              • 22788
              Nice start Tony
              • colin m
                • 8800
                • Colin
                • Stafford, UK
                I built a 1:72 Revell SE5 sometime ago and quite liked the little kit. Having said that, I think it came from a better mould than your example ! As for the mouldings not being smooth, is that Revell trying to reproduce 'canvas' used to cover the aircraft frame ?
                Colin M..
                • mossiepilot
                  • Jul 2011
                  • 2272
                  Good beginning Tony.
                  Tony.
                    Work has got in the way recently, but I started painting both models. I used Revell Aqua Colour, and they look terrible; like they were done with a pastry brush. I will strip them both and try again with Vallejo Model Colour. I'm sure it's partly, or maybe mostly, my poor technique, but my limited experience of Model Colour has been much more positive. It just seems more novice-friendly.
                    Tony
                    • colin m
                      • 8800
                      • Colin
                      • Stafford, UK
                      When I made the change to acrylics, it was recommended that the surface should be primed before painting. It certainly works for me. As well, when I'm brush painting, I always thin the paint a bit.
                        Thanks Colin. I am already a convert to the use of primer, but even so I can't get consistent results with the Aquacolor. Lightish shades seem OK - the beige on the underside of the triplane for example, but the green on the upper surfaces looks rubbish. It's all good experience, I suppose.
                        Tony
