Ian M's Lightning
    • 18269
    Ian M's Lightning
    Well due to technical problems my planed build was to be a twin stick T4 from 74 squadron. Due to having the WRONG airframe I will be doing a single seater from the same squadron..
    Here are the bits. I have a resin cock pit some where, I'll find that later.
    [ATTACH]75656.IPB[/ATTACH]
    This is the original boxing of the F6 that Airfix have just re boxed and to pimp it up a bit, I have a PE and white metal set from Flight path. As said I have a Neomega resin cockpit some place....
    The subject is a bare metal finish with black tail and spine.
    I'm off to find some photos of the 'gubbins' that are hidden in the spine....
    [ATTACH]75657.IPB[/ATTACH]
  • ojays
    • Oct 2011
    • 1713
    Originally posted by \
    Well due to technical problems my planed build was to be a twin stick T4 from 74 squadron. Due to having the WRONG airframe I will be doing a single seater from the same squadron..Here are the bits. I have a resin cock pit some where, I'll find that later.
    [ATTACH]75238[/ATTACH] [ATTACH]75237[/ATTACH]
    A couple of the photo's posted in the £11000 lightning post may be of help!
    Gregg
      • 22770
      Nice one Ian. So your going to show it opened up looking forward to this
        • 18269
        Thats the plan Ian. Its just a matter of finding out where and what to put in the holes.!
        I might have found an F1a/F3 just waiting for a reply. Found one for sale but the ad just said Airfis 1/48 EE Lightning... So I might just have to build two!!! (maybe just not at the same time though )
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          You could ask those nice people at FAST in Farnborough if they have any photo's, they have a T bird Lightning on display.
            • 18269
            yeah! Just got a reply Its an F1 version so I'm having that.... Watch this space...
            So it will be either the T4, or an F6 or in the event of total madness, both. Either way they will be tiger squadron birds.... I better check up on the Alclad stock...
            Thanks Rick, I'll see if I can find them and drop them a line.
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              If you want detail photo's of the outside I'll ask them if they will let me get closer. The museum is 5 mins away. It is in the original building number 1 of the airfield is listed and was the HQ of the RAF when it was formed on 1st April 1918. And it's well worth a visit.
                • 18269
                Sounds good Rick. If you find yourself with nowt better to do I would be interested. You could post them in the reference section for all to see.
                Cheers.
                  • 18269
                  Been having a look at the Flight path set.... I dont think I will be using much of it. The weapons and accessory parts yes. But the rest is to over thought.
                  • yak face
                    • Jun 2009
                    • 13840
                    • Tony
                    Looking forward to seeing this one Ian, I might even pluck up the courage to do mine ,its only been in the stash about 6 years!
                      • 18269
                      Hmph!
                      Just heard from the guy selling the F1 kit....there are parts missing and he wont sell it like that.... Bugger.
                      He has probably changed his mind or seen how much they go for on flea bay.
                      Ian m
                        Been having a look at the Flight path set.... I dont think I will be using much of it. The weapons and accessory parts yes. But the rest is to over thought.Ian M
                        I bought the Flight Path when I did my Lightning and reported at the time that I did not use much of it. An expensive waste.
                        Found this photo in my 1967 collection, I know it's not the Mk that you are planning but may be of some limited use.
                        Cheers Derek
                        [ATTACH]75793.IPB[/ATTACH]
                          • 18269
                          Thanks Derek I recall reading that actually, I looks good but just to over the top. A whole cockpit tub in PE.... I had a good look and there are a few bits I might use. Other wise its a fight to the death with the Aires resin wheel bays and jet pipes I might end up buying...
                          I cut the Omega resin cock pit parts from the casting blocks and primed them Not much to see so no photos yet.
                          Ian m
                            • 18269
                            Well I got the tub and bang seat painted. Sort of. I really think that I am due a new pair of glasses soon...
                            [ATTACH]75854.IPB[/ATTACH]
                            [ATTACH]75855.IPB[/ATTACH]
                            [ATTACH]75856.IPB[/ATTACH]
                            Still got a few gizmoes and dodabs to paint and the harness on the seat needs some metal. Off to see if I can find some undercart bays on the interweb.
                              • 22770
                              Looks good enough to me Ian
