Dave W's BAC Lightning
  • Dave W
    • Jan 2011
    • 4713
    This is my kit for the sig build.Not sure what markings I'm going to do it in yet.But it will definitely be a natural metal finish.Ive got a few extras for it. Namely a resin ejection seat and a PE set for the wheel bays.Not sure how difficult It's going to be to fit the PE.We shall see...
    Nice one Dave, my favourite Aircraft. It's a good kit so you will enjoy building it. Cheers Derek
      • 22771
      A very nice kit Dave
      It looks very familiar
      • Richi72
        • Sep 2013
        • 1100
        Nice one Dave,
        definitely following this build
        Cheers Richi
          • 18271
          Glad to see you join in the fun Dave.
          • Dave W
            • Jan 2011
            • 4713
            Thought I'd make a start on this whilst I wait for the paint to dry on my TSR2.I decided to start with the wings as I wanted to see if the Airwaves PE was any good.The PE designed for the undercarriage bay sidewalls is a very good fit.Unfortunately the same cannot be said for the PE intended for the ceiling of the U/C bays.As you can see from the photos it is not big enough to cover the area.It matches the cut out in the lower wing.But as the walls of the bays are molded further apart than the edges of the cut outs,there are gaps when this part is fitted in place.Very disappointing and for that reason I can't recommend this set.You would think the people who design these would do a test build to make sure they actually fit the model before putting them on sale to Joe and Josephine public.A small problem I have come across with the Airfix kit is the fit of the wing halves.If you just glue them as they are there will be a step up to the aileron on the underside.A small plastic card shim will sort this out though.
              • 22771
              It still looks a lot better than the kit plain look Dave
                • 18271
                I have also tried an Airwaves set, for another aircraft and I too was very disappointed, I stay well away from them now.
                Live and learn. A good school but rather expensive lessons. If there is a resin alternative, I tend to good for them. Easy to fit as well (most of the time).
                • Dave W
                  • Jan 2011
                  • 4713
                  I got some decals through the post from Hannants today.Im probably going to do the 74 sqdn aircraft with the black fin.
                    • 18271
                    Te he SNAP!
                    they do look good with the black against the silver.
                      Wow, looks like it could be a blinder, and looking good so far...
                      • Dave W
                        • Jan 2011
                        • 4713
                        I've assembled the intake ducting,cockpit and engine exhausts.Then I've glued these assemblies into the right fuselage half.Ive also added some pieces of lead sheet to keep the nose wheel on the ground.Im going to use the kit supplied instrument decals and will add them to the cockpit next.
                        • ojays
                          • Oct 2011
                          • 1713
                          Coming on nicely!
                          • Dave W
                            • Jan 2011
                            • 4713
                            Some more progress.Fuselage halves together,wings and tailplanes fitted.
                            • ojays
                              • Oct 2011
                              • 1713
                              Looking good.
                              There are several good photo's in this months 'Flypast' magazine that may be of interest Dave.
