tanktracks monogram sherman 4 hedge cutter
  • tanktrack
    • Jun 2012
    • 1429
    #16
    first mistake a 1/35 barrel does not fit a 1/32 its too small , a well I can use it on another shermanops:
    • tanktrack
      • Jun 2012
      • 1429
      #17
      making good progress this model is very good for a mid seventies kit
      [ATTACH]77294.IPB[/ATTACH]
      [ATTACH]77295.IPB[/ATTACH]
      [ATTACH]77296.IPB[/ATTACH]
      [ATTACH]77297.IPB[/ATTACH]
        Wow!! Looks excellent Steve.
        Will be a great build, I'm sure
          • 22788
          #19
          Looking good Steve
          • geegad
            • Mar 2010
            • 2329
            #20
            looking nice nice clean molding on this tank
            • tanktrack
              • Jun 2012
              • 1429
              #21
              does anyone know if you can get 1/32 tank crew figures as the ones in the kit are American I have 1/35 ones would they do or are they too small ?
                My opinion is will be too small...anyway you can try to build a figure without glue and show on front of the Sherman....your Kit is old, and sometimes the scale isn't exactlly what they said... ops:
                Hope you have luck!!!
                • tanktrack
                  • Jun 2012
                  • 1429
                  #23
                  getting a bit of paint on , I will have to get the base on the way soon
                  [ATTACH]77645.IPB[/ATTACH]
                  [ATTACH]77646.IPB[/ATTACH]
                  • Gern
                    • 9256
                    #24
                    Looking good Steve. Are all those sand bags included in the kit or are they aftermarket or scratch built?
                    Gern
                    • tanktrack
                      • Jun 2012
                      • 1429
                      #25
                      they are included in the kit
                      • monica
                        • Oct 2013
                        • 15169
                        #26
                        nice build Steve , do like the look off that one, and seen to be going together , well , like the sand bags as well,
                        have fun weathering them,
                        what type off men were you thing off using , as if there moving beside, the tank you could down set the tank a
                        little and have like a bit off mound from were the tracks press into the ground, and that would raise up the men
                        about 5 mm or so and if there ,kind off stooped over running , don,t think you would pick it up,
                        • tanktrack
                          • Jun 2012
                          • 1429
                          #27
                          thanks Monica for the ideas , I am doing a "bocage " type scene and I am working on the base as the paint dries on the tank I plan to use some Normandy troops from dragon following the tank through the hedge , and as you say with the tank in 1/32 and the figures in 1/35 I will have to be careful that they don't look too small
                          • tanktrack
                            • Jun 2012
                            • 1429
                            #28
                            I have found some airfix 1/32 British soldiers that may do if they a made well enough , i have measured a 1/35 soldier to the 1/32 American ones in the kit and they are definitely a bit bigger
                              Looking very good so far, Steve!!!
                              • tanktrack
                                • Jun 2012
                                • 1429
                                #30
                                I have got the base under way and some paint on the Sherman the figures are a work in progress
                                [ATTACH]77856.IPB[/ATTACH]
                                [ATTACH]77857.IPB[/ATTACH]
                                [ATTACH]77858.IPB[/ATTACH]
                                [ATTACH]77859.IPB[/ATTACH]
