papa 695's 1/72 Sherman M4 (two builds )
    Wow !! Great ideas, wait to see more...
    Enviado do meu GT-I8190 através de Tapatalk
    • geegad
      • Mar 2010
      • 2329
      #17
      Your knocking them out quick and doing a great job on them..and looking forward to seeing them dio's
      • tanktrack
        • Jun 2012
        • 1429
        #18
        liking good Ian
          Originally posted by \
          It will more than likely end up like Polux's little Tilly build
          No my God!!!
          Do it better!! My Tilly was an absolutely disaster!!!
            Wich product you will use Ian?
            Clear resin, silicone,vallejo still water...?
              • 22770
              #21
              Wich product you will use Ian?Clear resin, silicone,vallejo still water...?
              Going to try some clear resin Polux
                • 22770
                #22
                Ok got the lower half sanded to look like coral ( still needs painting )
                [ATTACH]77445.IPB[/ATTACH]
                [ATTACH]77446.IPB[/ATTACH]
                [ATTACH]77447.IPB[/ATTACH]
                [ATTACH]77448.IPB[/ATTACH]
                And painted the turret ( still needs weathering )
                [ATTACH]77449.IPB[/ATTACH]
                [ATTACH]77450.IPB[/ATTACH]
                [ATTACH]77451.IPB[/ATTACH]
                [ATTACH]77452.IPB[/ATTACH]
                • yak face
                  • Jun 2009
                  • 13840
                  • Tony
                  #23
                  To my eyes that looks absolutely spot on Ian! The crusty body will look just like its covered in coral and the turret looks just like it would if it had been left exposed to the weather for years , the bright orange rust eventually giving way to a darker colour like this -perfect! top work mate , how did you get the faded rust effect? cheers tony
                  • flyjoe180
                    • Jan 2012
                    • 12400
                    • Joe
                    • Earth
                    #24
                    I agree, that is looking very good Ian.
                      Me too Ian, looking very good
                        Very good effect, looks like the real one
                          The sherman looks well worn mate. Nice work. Certainly looks like coral.
                            • 22770
                            #28
                            Hi Tony to let you know how I did it firstly I have this set of paints [ATTACH]77501.IPB[/ATTACH]
                            So firstly I sprayed it all over with the shadow rust then while still wet sprayed dark rust to the sides, but not full covering the fist coat, this way it blends both colours together. Then I let it all dry, then sprayed dark rust again over the area of the first coat of dark rust then also whist its still wet used the medium rust colour to the sides of the raised areas then let that dry then medium rust again not totally coving the last coat whilst wet then light rust at the very edges let it all dry then a coat of light just to top it off This way I find out of the 4 colours you get around 8 different shades of rust
                            I hope you can understand
                              • 22770
                              #29
                              Ok here's where I'm at with the second build [ATTACH]77512.IPB[/ATTACH]
                              [ATTACH]77513.IPB[/ATTACH]
                              [ATTACH]77514.IPB[/ATTACH]
                              [ATTACH]77515.IPB[/ATTACH]
                              Will it pass as coral ?
                                I see coral Ian, and very nice must say!!
                                I'm wishing to see this build finished yet
