papa 695's 1/72 Sherman M4 (two builds )
    • 22770
    #46
    Its now out of the mould
    [ATTACH]78197.IPB[/ATTACH]
    [ATTACH]78198.IPB[/ATTACH]
    [ATTACH]78199.IPB[/ATTACH]
    [ATTACH]78200.IPB[/ATTACH]
    [ATTACH]78201.IPB[/ATTACH]
    [ATTACH]78202.IPB[/ATTACH]
      Genial
        Wow!
        What flavor is the pudding/gelee?
        Seriously now, will you keep in the container or remove it from there?
        Francesco
          Only just caught up with this, how did I miss it?
          Erm.... Wow! springs to mind, that is some superb work there, and in 1/72nd too. Very impressive.
            • 22770
            #50
            Originally posted by \
            Wow!What flavor is the pudding/gelee?
            Francesco
            It is out of the container Francesco I need to cut the lip away from the cast But that would mean lots and lots of sanding and polishing
            • monica
              • Oct 2013
              • 15169
              #51
              real nice ,crusty body covered in coral and the turret looks just great left exposed to the weather for years, the diver came out real well also,seen happy
              • flyjoe180
                • Jan 2012
                • 12400
                • Joe
                • Earth
                #52
                Love it Ian, wonderfully done. Impressive water effects on the surface.
                  Hi Ian.
                  I asking myself...is easy to sand this kind of product? Leave marks or lose the transparency?
                  Polux
                    • 22770
                    #54
                    Hi Ian.I asking myself...is easy to sand this kind of product? Leave marks or lose the transparency?
                    Polux
                    They say it can be sanded Polux as you would a canopy. I'm a little nervous to try it but I think I need to get rid of the lip left by the carton I used for the mould
                      Good luck Ian!!
                      Handle with care, like a baby....
                      • monica
                        • Oct 2013
                        • 15169
                        #56
                        i think you can cut it back useing a jigsaw with a fine blade,or buy hand with a coping /fine blade then sand it back,
                        and finely use wet/dry to get the shine back in, or ever give it a touch up with some resin painted on
                        hope that some help
                          • 18269
                          The name of that resin would be worth knowing...
                          The clarity is great and it didn't turn it into a blob!
                          Great work!
                          • monica
                            • Oct 2013
                            • 15169
                            #58
                            if you still have left over resin that you made the cast from use that, as as you saying some think else may meld it into a blob ops:
                            best would be to test it on a bit off ,of cut and see how it go,s 1st or if it will bond with the other resin you used
                              • 22770
                              #59
                              i think you can cut it back useing a jigsaw with a fine blade,or buy hand with a coping /fine blade then sand it back,and finely use wet/dry to get the shine back in, or ever give it a touch up with some resin painted on
                              hope that some help
                              Thanks for the tips Monica. I will get this sorted soon
                              • monica
                                • Oct 2013
                                • 15169
                                #60
                                hope it all turns out well for you, fingers crossed, just go slow,
