Terry's desert sig
    Interesting idea Terry
    Thanks to join in.
    Ps: I moved the thread on the right forum :P
    Polux
      Thanks to join in.
      Polux
      Thanks Polux I wasn't sure if it was in the right place.
        Hi Terry will be following this build mate
          Thanks Tommy.
            I nearly forgot to do an update on this build so here it is. I have started on the first building by putting three walls together and adding a frame work for the floors. Once this was done I added some stirrers as floor boards. I did have a bit of a set back as predicted by Moni when I removed the door. The front of the house basically ended up in four bits. Not to worry as I can make it look like it has been hit by a round.[ATTACH]103458.IPB[/ATTACH]
            [ATTACH]103459.IPB[/ATTACH]
            [ATTACH]103460.IPB[/ATTACH]
            [ATTACH]103462.IPB[/ATTACH]
            [ATTACH]103463.IPB[/ATTACH]
            [ATTACH]103464.IPB[/ATTACH]
            [ATTACH]103465.IPB[/ATTACH]
            [ATTACH]103466.IPB[/ATTACH]
            [ATTACH]103467.IPB[/ATTACH]
            [ATTACH]103469.IPB[/ATTACH]
            • monica
              • Oct 2013
              • 15169
              #21
              looks great Terry,sorry to hear that,had happened,but adds to the look of it all,
              the the one thing i hate with plaster,it dose that,and will alway be a bit you dont wont it to happen too,
              good use with the stirrers,i find them so hard to cut,the round ends i cut off with side cutters,the wood
              is like steel,
              all coming along nicely,
                Cracking work on the building Terry, coming along lovely mate
                  OK so I am now on to the desert build proper but now find I can't make my mind up on the layout. below are two photos which do you guys think looks best?[ATTACH]104059.IPB[/ATTACH]
                  [ATTACH]104060.IPB[/ATTACH]
                    I am leaning more towards the two houses being joined.
                      Over the last week I have made a start on the LRDG vehicles to give me an idea on how I want the dio layout to look. I am going to add a couple of German vehicles to the mix as I want it to look like there has been a bit of a fire fight at an out post. As yet I am unsure which way I prefer the buildings (seperate or joined). Does anyone have any thoughts on this? [ATTACH]104694.IPB[/ATTACH]
                      [ATTACH]104695.IPB[/ATTACH]
                      [ATTACH]104696.IPB[/ATTACH]
                      [ATTACH]104697.IPB[/ATTACH]
                      [ATTACH]104698.IPB[/ATTACH]
                      My thoughts are this on either of the layouts I want a German truck parked behind one of the buildings with maybe a Kubelwagen out front. with both either having or had there insignis removed or about to be destroyed by the LRDG patrol.
                        Those buildings looks really good!!
                        My vote is separate... Anyway could be nice to add something to unit them...
                        I think the buildings must be the protagonists, maybe is not usual...because most of us add these or other items to accompany the vehicles
                        Excellent dio so far
                        • grumpa
                          • Jan 2015
                          • 6142
                          #27
                          have some flooring to do myself , pity you too far to hire out
                          • Richi72
                            • Sep 2013
                            • 1100
                            #28
                            way cool.
                            Like the buildings great job so far Terry
                            Cheers Richi
                            • spanner570
                              • 15441
                              #29
                              Terry, how about keeping the main buildings apart, but join them with a simple arch / vehicle wide alley way, and have the flat roof going across to the tower as a sort of balcony complete with a concrete upstand around it? You could then put a doorway into the first floor of the tower.
                                Hi Terry I've just found this and I have to say iam impressed this is looking good so far.
                                scott
