Rick's Raspberry Ripple BAe Hawk
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    This will be my entry, the Airfix 1/48 Bae Hawk T1. I've got the kit and the paint but still have to find a set of decals in this scale and hopefully not clash with Joe's proposed Hawk markings in 1/72. I'll look for a set of resin seats if the kit ones are lousy.
    [ATTACH]112237.IPB[/ATTACH]
    [ATTACH]112238.IPB[/ATTACH]
    [ATTACH]112239.IPB[/ATTACH]
  • flyjoe180
    • Jan 2012
    • 12476
    • Joe
    • Earth
    Nice one Rick. I'll post mine up soon.
      Yep!! Is your idea!
      So you must open the way to the others... Let's see
        • 22788
        Nice one Rick.
        • rickoshea52
          • Dec 2011
          • 4076
          • Rick
          There are two after market decal sheets listed on Hannants' website and the cheaper option is out of stock, no matter as I think it would have duplicated Joe's version.
          Both are ETPS kites but one has a slightly different paint scheme and has ASTRA markings.
          [ATTACH]112943.IPB[/ATTACH]
          [ATTACH]112944.IPB[/ATTACH]
          • flyjoe180
            • Jan 2012
            • 12476
            • Joe
            • Earth
            That looks good Rick. Thicker side cheat lines and the red upper, truly raspberry ripple going on there
            • rickoshea52
              • Dec 2011
              • 4076
              • Rick
              Making a start with the cockpit of this little bird and its a bit spartan, the instrument panel requires delicate painting that my fingers won't manage and there are no decals in the kit. The bang seats are a bit bare too so I may try the Eduard detailing kit to liven things up with the IP and the seats, it's designed for the Italeri kit but I'm sure it can be made to fit.
              The intakes have been assembled too with some rough moulding to be found.
              [ATTACH]113667.IPB[/ATTACH]
              [ATTACH]113668.IPB[/ATTACH]
              [ATTACH]113669.IPB[/ATTACH]
              • flyjoe180
                • Jan 2012
                • 12476
                • Joe
                • Earth
                Looks good Rick.
                  • 22788
                  I agree with Joe, Rick
                  • yak face
                    • Jun 2009
                    • 13871
                    • Tony
                    Looking good rick , The seats dont look too bad to me , once theyve got some belts on they should be great (certainly better than we used to get supplied by the kit manufacturers a few years ago!!) cheers tony
                    • rickoshea52
                      • Dec 2011
                      • 4076
                      • Rick
                      These arrived today, time to crack on.
                      [ATTACH]114509.IPB[/ATTACH]
                      • flyjoe180
                        • Jan 2012
                        • 12476
                        • Joe
                        • Earth
                        Nice one Rick, these will add to the completed model nicely.
                        • colin m
                          • 8806
                          • Colin
                          • Stafford, UK
                          Nice goodies there.
                            • 22788
                            Very nice Rick
                            • rickoshea52
                              • Dec 2011
                              • 4076
                              • Rick
                              Slow progress with this. Cockpit sidewalls, floor and bulkheads painted and fitted. I'm using the Eduard PE set for the Italeri version of this aircraft and I'm not too sure it will look so good in this kit. The side panels are fitted with the IP still to fit.
                              The kit instructions tell you to glue the wings together before cutting off the flaps if you want them positioned down - it's better to remove the flaps before doing this.
                              [ATTACH]116526.IPB[/ATTACH]
                              [ATTACH]116527.IPB[/ATTACH]
                              [ATTACH]116528.IPB[/ATTACH]
                              [ATTACH]116529.IPB[/ATTACH]
