Tracking (Infentryman 1/16 Figure)
    Well this is as good as it gets from me, im getting better but got a long way to go.
    [ATTACH]37778.vB[/ATTACH][ATTACH]37779.vB[/ATTACH][ATTACH]37780.vB[/ATTACH]
    Ok back to the torso & lets see what all the kings horses & all the kings men can do in putting him back together again.
    [ATTACH]41908.IPB[/ATTACH]
    [ATTACH]41909.IPB[/ATTACH]
    [ATTACH]41910.IPB[/ATTACH]
      • 22771
      #17
      I'm sure you can put him back together without all the kings horses and men, and still not see the cracks John
        Well made a start on the torso, the Rt arm was raised up to the shoulder & bent scross the chest so had to cut & reposition pluss redo the sleeve & turnup.
        [ATTACH]37834.vB[/ATTACH][ATTACH]37835.vB[/ATTACH][ATTACH]37836.vB[/ATTACH]
        May need to adjust the hand as he will be holding a knife which i will scratch build.
        [ATTACH]41961.IPB[/ATTACH]
        [ATTACH]41962.IPB[/ATTACH]
        [ATTACH]41963.IPB[/ATTACH]
        • spanner570
          • 15438
          #19
          Some excellent butchery going on here John, it's one great thread.
          Good work, well done thus far....
          Ron
            Ok had a little tinker with this bit, bit more filler & sanding and quick primer to check join lines all seems well.
            [ATTACH]37930.vB[/ATTACH][ATTACH]37931.vB[/ATTACH][ATTACH]37932.vB[/ATTACH]
            Hope it makes the grade, advice would be nice.
            [ATTACH]42057.IPB[/ATTACH]
            [ATTACH]42058.IPB[/ATTACH]
            [ATTACH]42059.IPB[/ATTACH]
              Well started to work on humpty dumpty again & also started the base.
              The theme for this figure is some commando's have got through there lines & he is about to start tracking them.
              [ATTACH]38093.vB[/ATTACH][ATTACH]38094.vB[/ATTACH][ATTACH]38095.vB[/ATTACH][ATTACH]38096.vB[/ATTACH][ATTACH]38097.vB[/ATTACH][ATTACH]38098.vB[/ATTACH]
              [ATTACH]42207.IPB[/ATTACH]
              [ATTACH]42208.IPB[/ATTACH]
              [ATTACH]42209.IPB[/ATTACH]
              [ATTACH]42210.IPB[/ATTACH]
              [ATTACH]42211.IPB[/ATTACH]
              [ATTACH]42212.IPB[/ATTACH]
                Well been working on the base over the last two days & i think it's just about done, what do u think ??.
                [ATTACH]38183.vB[/ATTACH][ATTACH]38184.vB[/ATTACH][ATTACH]38185.vB[/ATTACH][ATTACH]38186.vB[/ATTACH][ATTACH]38187.vB[/ATTACH][ATTACH]38188.vB[/ATTACH][ATTACH]38189.vB[/ATTACH]
                O'well back to the torso.
                [ATTACH]42289.IPB[/ATTACH]
                [ATTACH]42290.IPB[/ATTACH]
                [ATTACH]42291.IPB[/ATTACH]
                [ATTACH]42292.IPB[/ATTACH]
                [ATTACH]42293.IPB[/ATTACH]
                [ATTACH]42294.IPB[/ATTACH]
                [ATTACH]42295.IPB[/ATTACH]
                  Had a little play with the MP40, drilled out the four sight just for the hell of it.
                  [ATTACH]38202.vB[/ATTACH][ATTACH]38203.vB[/ATTACH]
                  LOL
                  [ATTACH]42308.IPB[/ATTACH]
                  [ATTACH]42309.IPB[/ATTACH]
                    • 22771
                    #24
                    And why not John you love your fiddling dont ya some great work mate
                      Started to scratch build the knife & finished the lower half of humpty dumpty, went better than i thought it would.
                      [ATTACH]38240.vB[/ATTACH][ATTACH]38241.vB[/ATTACH][ATTACH]38242.vB[/ATTACH][ATTACH]38243.vB[/ATTACH][ATTACH]38244.vB[/ATTACH]
                      Just started on the torso this morning, this is going to need a lot of work.
                      [ATTACH]38245.vB[/ATTACH][ATTACH]38246.vB[/ATTACH]
                      [ATTACH]42346.IPB[/ATTACH]
                      [ATTACH]42347.IPB[/ATTACH]
                      [ATTACH]42348.IPB[/ATTACH]
                      [ATTACH]42349.IPB[/ATTACH]
                      [ATTACH]42350.IPB[/ATTACH]
                      [ATTACH]42351.IPB[/ATTACH]
                      [ATTACH]42352.IPB[/ATTACH]
                        Hi all just thought i would give you an update on this figure, well humpty is all back together & doing well and has just had its first coat of paint.
                        All webbing has been sanded off & will be scratch built.
                        I'll not bother you with pic's untill it's done & dusted as we all seem to be watching the half naked lady in chain-mail.
                        Regards
                          Ok if you insist.
                          [ATTACH]38422.vB[/ATTACH][ATTACH]38423.vB[/ATTACH][ATTACH]38424.vB[/ATTACH][ATTACH]38425.vB[/ATTACH][ATTACH]38426.vB[/ATTACH]
                          Just got to scratch build the webbing & bingo.
                          [ATTACH]42507.IPB[/ATTACH]
                          [ATTACH]42508.IPB[/ATTACH]
                          [ATTACH]42509.IPB[/ATTACH]
                          [ATTACH]42510.IPB[/ATTACH]
                          [ATTACH]42511.IPB[/ATTACH]
                            Made a start on the webbing today & added a cigar and watch.
                            [ATTACH]38500.vB[/ATTACH][ATTACH]38501.vB[/ATTACH]
                            John.
                            [ATTACH]42574.IPB[/ATTACH]
                            [ATTACH]42575.IPB[/ATTACH]
                              • 22771
                              #29
                              Some great work there John, infact FANTASTIC work a total rebuild of the figure
                                Thanks Ian, at times i didnot think it was going to work out but i went with it & it seem to come together in the end.
